itemnquery and qlayer not found, NAME vs GROUP
Wim Blanken
w.blanken at GEON.NL
Tue Dec 7 16:03:26 EST 2004
Hello Ken,
Just had the same problem with an app we are developing....
It seems you are right about the itemnquery problem, the documentation
is clearly wrong about this.
I had to merge my query layers (point, line and polygon) into one polygon
layer to get this working......
Would be nice if this worked with groups.
Kind Regards,
Wim Blanken
The Netherlands.
----- Original Message -----
From: "Geographic Resource Solutions" <grs at GRSGIS.COM>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, December 07, 2004 5:57 PM
Subject: [UMN_MAPSERVER-USERS] itemnquery and qlayer not found, NAME vs
GROUP
> Hi List,
> Last night I came finally got past a problem I had with itemnquery where I
> kept getting the qlayer not found message even though it was in my
> mapserver statement. My qlayer specified a layer GROUP name rather a
> layer
> NAME value. By chance I tried the actual layer NAME value and the locate
> feature worked.
> Can someone confirm that this call/function needs a qlayer value based on
> a
> NAME value rather than a GROUP value.
> Secondly, now that the function is returning the selected feature, none of
> the other features specified as layers to be drawn are being displayed.
> Is
> this for the same reason ? Does all layer input for commands like this
> have to be by name rather than group ?
> Thanks,
> Ken
> 1125 16th Street, Suite 213
> Arcata, CA 95521
> Phone: (707) 822-8005
> Fax: (707) 822-2864
> www.grsgis.com
