Segfault under Mapscript/Perl - Mapserver 4.4.0
Aaron Craig
mercutio at POBOX.COM
Thu Dec 9 09:00:33 EST 2004
I'm getting a segmentation fault when I ask for a layer's name under Perl.
The following script (make sure you've got mapscript.pm installed, copy
the text into a file, chmod 0755 the file and run it off the command
line) demonstrates the error.
I've done a fresh build/install of mapserver 4.4.0 and the perl module
in mapscript/perl inside the 4.4.0 tarball.
Any insight would be appreciated.
#!/usr/bin/perl
use strict;
use warnings;
use mapscript;
$| = 1;
my $sMapFileName = "test.map";
print "Creating test map file...";
MakeMapfile();
print "OK\n";
print "Creating map object...";
my $map = new mapscript::mapObj($sMapFileName) || die("Couldn't create
map instance");
print "OK\n";
my $nLayerCount = $map->{numlayers};
print "Getting information for $nLayerCount layer(s)\n";
for(my $i = 0; $i < $nLayerCount; $i++)
print "Getting layer at index $i...";
my $lyr = $map->getLayer($i) || die("Couldn't get a layer for index
$i");
print "OK\n";
print "Getting layer name...";
my $sLayerName = "";
# comment out this line and the segfault disappears
$sLayerName = $lyr->{name} || "No name";
print "OK\n";
print "$i: ";
print "$lyr: ";
print "$sLayerName\n";
print "Cleaning up...";
unlink $sMapFileName;
print "OK\n";
sub MakeMapfile
open(OUT, ">$sMapFileName") || die("Couldn't create test mapfile: $!");
print OUT qq{MAP
NAME "Test"
STATUS ON
EXTENT -71.5 39.5 -63.0 46.0
SIZE 504 385
IMAGETYPE PNG
UNITS DD
OUTPUTFORMAT
NAME PNG
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
END
SYMBOL
TYPE ELLIPSE
NAME "circle"
POINTS 1 1 END
FILLED TRUE
END
SYMBOL
TYPE VECTOR
NAME "plus"
POINTS .5 0 .5 1 -99 -99 0 .5 1 .5 END
END
LAYER
NAME "clickline"
TYPE LINE
STATUS OFF
END
LAYER
NAME "clickline1"
TYPE LINE
STATUS OFF
END
LAYER
NAME "clickline2"
TYPE LINE
STATUS OFF
END
LAYER
NAME "clickline3"
TYPE LINE
STATUS OFF
END
LAYER
NAME "clickline4"
TYPE LINE
STATUS OFF
END
END
close OUT;
Aaron Craig
mercutio at pobox.com
Get Firefox!
http://www.spreadfirefox.com/?q=affiliates&id=0&t=1
