How do I hide a layer from WMS GETCAPABILITIES XML?
Till Adams
adams at TERRESTRIS.DE
Fri Dec 17 04:51:21 EST 2004
Brent Fraser wrote:
> I'm using the new TYPE TILEINDEX layer (pointed to by an
> indexed raster layer) and I'd like to prevent this layer from being
> listed in the GETCAPABILITIES XML (and hence listed as a "valid" layer
> in various WMS clients).
> Any thoughts?
> Windows2000, IIS 5.0
> MapServer version 4.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=JPEG
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Thanks!
> Brent Fraser
> GeoAnalytic Inc.
> Tel:(403) 213-2700
> bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>
> www.geoanalytic.com <http://www.geoanalytic.com>
Dear Brent,
we have developped a workaround, which is not 100% OGC WMS:
In the mapfile in the expression we have implemented a parameter, e.g.:
CLASS
EXPRESSION [index] > %user%
COLOR 0 0 0
END
So the mapfile does not deliver any map, just a white image. Then we use
the GetStyle-request to generate a Styled Layer Descriptor (SLD) from
the actual mapfile. In this SLD we change the "%user%" in the filter
with a key on demand, which we assigned to a registered user (this is
possible in the Mapbender client suite).
When a registerd user demands a map, the map-request only can send a
"usable" map, when the correct SLD assigned to the getMap request:
http:// .... &getMap& .... & SLD=URL_to_SLD.xml
The client changes the "%user%" in the XML on demand (pure PHP) with in
this case "0", so that the filter in the SLD looks like this
FILTER EXPRESSION [index] > 0
Just some thoughts, may they'll help you ...
Greetings from Bonn, Till
