Printing To Scale - revisited
Kristjan Annus kristjan at TARKVARASTUUDIO.EE
Fri Dec 17 04:42:29 EST 2004
I have used just HTML and CSS
<img src="tmp/1103275875918521.gif" border=0 style="width:15cm;height;15cm">
You can set the print width and height in cm.
It works fine in IE at least, I have not tried the other browsers
because it works in
specialised application.
Kristjan
> Thank you everyone for the help.  I've decided to look into the PDF
> option.  Is the built-in PHP PDF API (oh the acronyms!) the best place
> to start:
> http://us2.php.net/manual/en/ref.pdf.php
> Or is there something else / better I should be working with?
> Thanks.
> -Abe
