[Mapserver-users] area Calculation in polygon-shapes
Norman Vine
nhv at cape.com
Mon Feb 2 11:07:01 EST 2004
> It is easy to calculate just get the polygon shape object and extract
> the polygon vertices. Then walk through the line segment and sum the
> area under the line segment. Or if the vertex points are in array v
> then in sudo-code:
> area = 0;
> for (i=1; i<numPoints; i++) {
> area = area + (v[i].x - v[i-1].x)*(v[i-1].y + (v[i].y - v[i-
> 1].y)/2.0);
> // and close the gap if any between the last and the first
> area = area + (v[0].x - v[numPoints-1].x)*(v[numPoints-1].y + (v[0].y
> - v[numPoints-1].y)/2.0);
Note that this is a 'flat earth' solution and the correspondence
of the solution obtained with what a surveyor might measure on
the actual 'ground' is *very* dependent on the size of the area,
it's location and the projection method used.
For example if a latlon representation of the points is used
this will be ~accurate only for small areas near the equator.
http://math.rice.edu/~pcmi/sphere/
http://www.geodyssey.com/papers/ggelare.html
Cheers
Norman
