[Mapserver-users] area Calculation in polygon-shapes
woodbri at swoodbridge.com woodbri at swoodbridge.com
Mon Feb 2 13:45:35 EST 2004
Ack, you are right when applying it to GIS problems. In fact if you
use it with lat/long data you will end up computing a result in
degrees squared! Not the most intuitive units :)
Which points out an important fact that you need to be aware of for
any solution - you need to know the limits and assumptions of a
solution before you apply it to a problem. For example are you trying
to compute the area of a surface contained within a polygon, How is
the polygon projected onto the surface? Is the surface smooth or has
it terrain? etc, etc.
If you don't care about most or all of this, my solution below might
work for some simple cases, but Norman's links will give you more
generalized or other specific solution that may be more valuable.
-Steve
On 2 Feb 2004 at 11:07, Norman Vine wrote:
> > It is easy to calculate just get the polygon shape object and extract
> > the polygon vertices. Then walk through the line segment and sum the
> > area under the line segment. Or if the vertex points are in array v
> > then in sudo-code:
> > area = 0;
> > for (i=1; i<numPoints; i++) {
> >   area = area + (v[i].x - v[i-1].x)*(v[i-1].y + (v[i].y - v[i-
> > 1].y)/2.0);
> > // and close the gap if any between the last and the first
> > area = area + (v[0].x - v[numPoints-1].x)*(v[numPoints-1].y + (v[0].y
> > - v[numPoints-1].y)/2.0);
> Note that this is a 'flat earth' solution and the correspondence
> of the solution obtained with what a surveyor might measure on
> the actual 'ground' is *very* dependent on the size of the area,
> it's location and the projection method used.
> For example if a latlon representation of the points is used
> this will be ~accurate only for small areas near the equator.
> http://math.rice.edu/~pcmi/sphere/
> http://www.geodyssey.com/papers/ggelare.html
> Cheers
> Norman
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
