[Mapserver-users] I have some landsat 7 data that I want to tile : overlap + transparency
Ed McNierney ed at topozone.com
Mon Feb 2 19:57:04 EST 2004
Stephen -
Can you explain what results you ARE getting, and what input parameters
you're using?  You've said you have "no luck", but we don't know what
that means.
Do you know what spatial resolution per pixel you are or should be
using?  That is an important part of the picture.
ANY image you request that is 1,800 pixels across will be 300 DPI at 6
inches width.  WIDTH=1800 is all you need.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
-----Original Message-----
From: Stephen Clark [mailto:stephen.clark at focus.ca]
Sent: Monday, February 02, 2004 3:30 PM
To: Stephen Clark; Ed McNierney; Kralidis,Tom [Burlington]; Frank
Warmerdam
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] I have some landsat 7 data that I want to
Ed or others,
If you have the time could you look at the LAYER below and help me out
with the appropriate parameters to get a 300 dpi image at 6 inches using
the BBOX, WIDTH and HEIGHT centering on UTM Zone 10 coordinates 583695,
6267684.
Has there been some discussions on this in the Archives because I have
come up with a blank on this..?
thanks
Stephen
----- Original Message -----
To: "Ed McNierney" <ed at topozone.com>; "Kralidis,Tom [Burlington]"
<Tom.Kralidis at ec.gc.ca>; "Frank Warmerdam" <warmerdam at pobox.com>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, February 02, 2004 9:14 AM
> Ed,
> How would I do that with the following layer for CanImage:
> e.g., using the  BBOX parameter ???
> LAYER # Centre d'information Topographique - CIT Sherbrooke
>     NAME "CANIMAGE"
>     TYPE RASTER
>     OFFSITE 0 0 0
>     STATUS on
>     CONNECTIONTYPE WMS
>     CONNECTION "http://wms.cits.rncan.gc.ca/cgi-bin/cubeserv.cgi?"
>     METADATA
>       "wms_title" "CANIMAGE"
>       "wms_name" "CANIMAGE:CanImage/CanImage"
>       "wms_server_version" "1.1.0"
>       "wms_srs" "epsg:26910"
>       "wms_format" "image/png"
>    END
>    PROJECTION
>       "init=epsg:26910"
>     END
> END #
> Thanks
> Stephen
> From: "Ed McNierney" <ed at topozone.com>
> To: "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca>; "Stephen
Clark"
> <stephen.clark at focus.ca>; "Frank Warmerdam" <warmerdam at pobox.com>
> Sent: Friday, January 30, 2004 6:51 PM
> Subject: RE: [Mapserver-users] I have some landsat 7 data that I want
to
> Folks -
> The concept of a 300 dpi image from spatial imagery is nothing more
than
> a convenient fiction.  EVERY WMS command produces a 300 dpi image - at
a
> certain output scale.
> You need to define one more variable - the geographic dimensions of a
> pixel.  This will let you calculate the image size you want.  Say, for
> example, you want to create a 300 dpi image in which each pixel
> represents 15 meters (in each dimension).  This means each inch on the
> output product will be 300 x 15 meters, so your output scale is 1 inch
> 300 x 15 meters or 1 inch = 300 x 15 x 39.37 inches - a scale of
> 1:177,165.
> If you'd like to do that, and produce a 6" x 6" 300 dpi image at a
> resolution of 15 meters per pixel, your WMS request asks for 6 x 300 x
> 15 or 27,000 meters in each dimension (in the BBOX parameter) and asks
> for a WIDTH and HEIGHT of 1,800 pixels (6 inches at 300 dpi).
> If you'd like the image to be 10 meters per pixel, or 30 meters per
> pixel, you would request a BBOX where delta X and delta Y were both
> 18,000 meters or 54,000 meters respectively.
> - Ed
> Ed McNierney
> TopoZone.com
> From: Kralidis,Tom [Burlington] [mailto:Tom.Kralidis at ec.gc.ca]
> Sent: Friday, January 30, 2004 7:58 PM
> To: 'Stephen Clark'; Frank Warmerdam
to
> > Sent: Friday, January 30, 2004 7:57 PM
> > To: Kralidis,Tom [Burlington]; Frank Warmerdam
want
> > Tom,
> > Is this the same as the CANIMAGE WMS layer from :
> The CanImage layer is a processed set, with no overlaps, at 15m
> resolution.
> The CCRS Landsat are band 743, as distributed by GeoGratis.  Same base
> product, different pre-processing done to the data.  IMHO, the
CanImage
> product looks more seamless.
> > If so I already have this layer added to MapServer.
> > My use of Landsat 7 Imagery is for a backdrop in my PDF files.  But
I
> > cannot get the WMS server to produce a 300 dpi image so I need to
copy
> > them locally to produce the 300 dpi PDF files.
> > Do you know of a WMS command that will produce an image ad a
> > particular DPI?
> No, anyone else got an idea here?
> ..Tom
> > thanks
> > Stephen
> > From: "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca>
> > To: "'Stephen Clark'" <stephen.clark at focus.ca>; "Frank Warmerdam"
> > Sent: Friday, January 30, 2004 2:59 PM
want
> > > Hi Stephen,
> > > What are your requirements for using the Landsat 7 Orthoimagery in
> > > MapServer?
> > > The CCRS WMS has the entire Landsat 7 Orthorectified Imagery
> > > collection, which is on GeoGratis, available as OGC:WMS:
> > > URL:
http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi
> > > Layer name: L7O_B743:CEOWARE2
> > > Note that this layer is also timestamped, i.e. you can
> > query via TIME
> > > in OGC:WMS also.  The scenes' black areas are transparent.
> > > Just thought it'd be easier to point to an OGC:WMS of this
> > data rather
> > than
> > > roll your own.
> > > Another comment: I'd be interested, as a separate exercise, how
> > > MapServer deals with overlapping images in a given layer.
> > What kind
> > > of algorithm is done between scenes which overlap?
> > > Thanks
> > > ..Tom
> > > Tom Kralidis
> > > Systems Scientist
> > > Environment Canada
> > > Tel: +01-905-336-4409
> > > http://www.ec.gc.ca/cise/
> > > > Sent: Friday, January 30, 2004 6:52 PM
> > > > To: Frank Warmerdam
> > > > Frank,
> > > > My landsat data is from the Geogratis web site :
http://geogratis.cgdi.gc.ca/download/landsat_7/ortho/geotiff/utm/
> > > > Specifically these three scenes as example:
> > > > tm/047021/
> > > > tm/048021/
> > > > tm/049021/
> > > > I compressed the files to ECW and produced this layer:
> > > > LAYER
> > > >   NAME landsat_048_021_rgb
> > > >   DATA
"d:/datasets/imagery/landsat/ecw/048021_0100_990804_l7_743_utm10.ecw"
> > > >   TYPE RASTER
> > > >   STATUS ON
> > > >   TRANSPARENCY 60
> > > >   # turn off the black background in the image files
> > > >    OFFSITE 0 0 0
> > > > END
> > > > >Do all the images have the same background value?   YES
> > -- they do.
> > > > There is a residual amount of black fuzziness around the scenes
> > > > after using the above OFFSITE command.
> > > > Here is a LAYER file for the tiled index of Landsat scenes:
> > > > LAYER
> > > >   NAME landsat_tile
> > > >   TILEINDEX "d:/datasets/imagery/landsat/landsat_index.shp"
> > > >   TILEITEM "location"
> > > >   TYPE RASTER
> > > >   STATUS ON
> > > >   TRANSPARENCY 60
> > > >   OFFSITE 0 0 0
> > > >   METADATA
> > > >     WMS_TITLE "Lansdat 7 Imagery "
> > > >     WMS_ABSTRACT "N/A"
> > > >     WMS_SRS "EPSG:26910"
> > > >   END
> > > > END
> > > > But this tiled layer does not have any transparency.  How would
I
> > > > fix this?
> > > > thanks
> > > > Stephen
> > > > From: "Frank Warmerdam" <warmerdam at pobox.com>
> > > > To: "Stephen Clark" <stephen.clark at focus.ca>
> > > > Sent: Friday, January 30, 2004 2:31 PM
> > > > > Stephen Clark wrote:
> > > > > > Hi All,
> > > > > > I have some landsat 7 data that I want to tile but the
scenes
> > > > > > overlap.
> > > > > > Can I use some sort of command that can be added to the
> > > > "gdaltindex"
> > > > > > command to add a transparency value to these scenes
> > so that the
> > > > > > overlap areas can show through.
> > > > > Stephen,
> > > > > Do all the images have the same background value?  If
> > so, use it
> > > > > as the offsite value for the whole layer and it will be used
> > > > with all the
> > > > > images. The other alternative is to store the tiles in a
format
> > > > > for which GDAL recognises "nodata" values, but this isn't very
> > > > convenient
> > > > > to arrange. There is no way to include nodata values in
> > the raster
> > > > > tile index.
> > > > > Best regards,
> > > > > I set the clouds in motion - turn up   | Frank Warmerdam,
> > > > > light and sound - activate the windows |
> > http://pobox.com/~warmerdam
> > > > > and watch the world go
> > round - Rush    | Geospatial
> > > > Programmer for Rent
> > > > _______________________________________________
> > > > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > > > http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
