[Mapserver-users] Dynamic creation of shapefiles ...
Lowell Filak
lfilak at medinaco.org
Thu Feb 5 15:42:46 EST 2004
You may want to include some of your code, as the method you are using
should work.
Lowell
The following message was sent by "Murilo Lacerda Yoshida"
<murilo.yoshida at agx.com.br> on Thu, 5 Feb 2004 18:10:26 -0200.
> Hi all,
> I am trying to create dynamically a shapefile, with polygon shapes,
> but I am having trouble to do it.
> If I understood the documentation, I have to do several lines with the
> points that I have, and add one by one to the shape object, and then add
> the shape object to the shapefile, is that correct?
> I tried this way, but it didn't work. SO I tried to do a line with all
> my points and then add this line to my shape object, and then add this
> shape object to the shapefile object. Still don't work.
> Am I doing something wrong? I saw once a example at the mapserver wiki
> about this, but I couldn't find it again.
> Thanks in advance,
> Murilo
