[Mapserver-users] shape file reprojection on the fly.
Pericles S. Nacionales
nacional at cbs.umn.edu
Thu Feb 5 22:27:14 EST 2004
Amit,
http://mapserver.gis.umn.edu/doc40/wms-server-howto.html
If you want to test your wms server, test against
http://demo.cubewerx.com/demo/cubexplor/cubexplor.cgi or some other WMS
clients.
-Perry
On Thu, 2004-02-05 at 18:06, Amit S BEHERE wrote:
> I am talking about WMS (for now) i.e the WMS GetMap Request. Do you mean
> that I can specify a list of epsg codes in the wms-srs parameter so that
> as long as the WMS getMap request has one of those codes for srs it will
> return the right image ?
> to put the problem more clearly
> 1. I have a map file with several layers.
> 2. I have set it up as a WMS server
> 3. It has a certain output projection defined in the map object
> 4. Each layer has a projection for the data that layer uses.
> 5. I can send OGIS WMS GetMap request to my mapservice. One of the
> request parameters is SRS. As long as I give the SRS the same as the espg
> code I specified in the map object, I assume everything works fine (haven't tried
> it yet!)
> 6. I specify a list of epsg codes in the wms-srs parameter.
> 7. Does that mean that as long as I sent OGIS WMS getmap request with srs
> that exists in the list I specfied in the above step I would get
> the correct image back? Is this right and am I even making any sense?
> This projection stuff is a little bit confusing!
> Amit Behere.
> UCSD.
> "Technology doesn't make your life more difficult or easy, it just changes
> the rules"......Vishwanathan Anand
> On Thu, 5 Feb 2004, Pericles Nacionales wrote:
> > Can of worms, I tell you... :)
> > When you say OGIS are you talking about WMS/WFS? If so, that's where the
> > METADATA "wms_srs" parameter is for. Specify the epsg codes for all
> > projections you want supported. Perhaps the wms folks can confirm this?
> > See http://mapserver.gis.umn.edu/doc40/wms-server-howto.html for more
> > info.
> > -Perry
> > On Thu, 5 Feb 2004, Amit S BEHERE wrote:
> > > Hi,
> > > I have an additional question on this one. I understand that the
> > > projection in the MAP object is the output projection. However say I have
> > > a map with a few layers and I want to do a OGIS get map request on one or
> > > more
> > > layer(s). So unless I do the request in the same SRS as the one defined on
> > > the map object I am not going to get useful stuff back. Is that right ?
> > > So whats the use of the SRS field in the OGIS Getmap request ?
> > > Is there any way I can send th OGIS getmap request with an srs thats
> > > different from the one specified on the map object and have it return the
> > > correct image.
> > > -Amit
> > > Amit Behere.
> > > UCSD.
> > > On Wed, 4 Feb 2004, Pericles S. Nacionales wrote:
> > > > Correct. The projection definition on the main MAP object is your
> > > > output projection and the projection definition in your LAYER object is
> > > > whatever projection your data is in. See
> > > > http://hypnos.cbs.umn.edu/projects/tutorial/example1-6.html for an
> > > > example.
> > > > -Perry
> > > > On Wed, 2004-02-04 at 16:30, Jason M. Nielsen wrote:
> > > > > To reproject shape files on the fly can you simply define a projection for the
> > > > > main portion of your map and then also provide one in the definition of a layer?
> > > > > Resulting in the proj in the layer def being transformed to the one in the main
> > > > > part of the map file.
> > > > > Someone beat me with a clue stick if I am off in left field on this.
> > > > > This mail sent through IMP: http://horde.org/imp/
> > > > > _______________________________________________
> > > > > Mapserver-users mailing list
> > > > > Mapserver-users at lists.gis.umn.edu
> > > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > > > "He's no geek.His tan's too good." -Benjamin Choate
