[Mapserver-users] shape file reprojection on the fly.
Frank Warmerdam
warmerdam at pobox.com
Fri Feb 6 00:03:12 EST 2004
Pericles Nacionales wrote:
> Can of worms, I tell you... :)
> When you say OGIS are you talking about WMS/WFS? If so, that's where the
> METADATA "wms_srs" parameter is for. Specify the epsg codes for all
> projections you want supported. Perhaps the wms folks can confirm this?
> See http://mapserver.gis.umn.edu/doc40/wms-server-howto.html for more
> info.
Peri / Amit,
I believe the wms_srs parameters in the mapfile metadata are just used to
determine what SRS'es will be advertised as supported in the WMS capabilities
document. As far as I know any coordinate system in the PROJ.4 epsg support
file will work even if it wasn't explicitly listed in the wms_srs list for
the server.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
