[Mapserver-users] Virtual Spatial Data
we wei
mapgisnewbies at yahoo.com
Sat Feb 7 10:05:33 EST 2004
Frank,
Thanks a lot for your help. The connection is working
right now and the connection throught mapserver is
working, too 'coz it didn't throw me the error like
"OGR ERROR: files not found or format not supported".
But I am now dealing with another problem that I have
no clue. I set up a virtual file that with the
following content:
<OGRVRTDataSource>
<OGRVRTLayer name="climate">
<SrcDataSource>ODBC:user/user at PostgresqlDSN</SrcDataSource>
<SrcLayer>climate</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns"
x="long" y="lat"/>
</OGRVRTLayer>
</OGRVRTDataSource>
I put my OGRVRTLayer's name as my table's name
"climate". is it okay ? and i didn't put <LayerSRS>
'coz I am using the lat and long data without any
projection.
And my mapfile is as below:
MAP
NAME VRTDEMO
STATUS ON
SIZE 400 300
SYMBOLSET ../etc/symbols.sym
EXTENT -2200000 -712631 3072800 3840000
UNITS METERS
SHAPEPATH "../data"
IMAGECOLOR 255 255 255
FONTSET ../etc/fonts.txtition
WEB
IMAGEPATH "/var/html/www/VRT/imagepath/imagetmp"
IMAGEURL "/imagepath/imagetmp"
LOG "error.log"
METADATA
"wms_title" "Virtual Spatial Data Demo"
"wms_onlineresource"
"http://127.0.0.1/cgi-bin/mapserv_40?map=/var/www/html/VRT/htdocs/vrt_wms.map&service=WMS"
END
PROJECTION
"init=epsg:42304"
END
LAYER
NAME "vrtlayer"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "virtual.ovf"
DATA "climate"
STATUS ON
PROJECTION
"proj=latlong"
END
CLASS
SYMBOL 2
SIZE 8
COLOR 0 0 0
END
END
And i put the mapfile and the .ovf file in the same
location.
and then I used the wms to open this image as this
http://localhost/cgi-bin/mapserv_40?map=/var/www/html/VRT/htdocs/vrtdemo.map&service=WMS&request=getmap&version=1.1.1
However, I got something weird. It gave me a whole
bunch of odd characters like the boxs and something
else but starts with &PNG. It didn't generate an
image to me.
Do you have any idea of what's going wrong or do you
have any method for me to generate more information
for debugging?
Thanks!
--- Frank Warmerdam <warmerdam at pobox.com> wrote:
> we wei wrote:
> > Hi list,
> > I am working on a problem in connecting ODBC to
> postgresql from
> > mapserver. I am using the suggestion from wiki,
> but i have a question
> > on the tip wiki provided though.
> > It mentioned that we need to configure the apache
> by
> > 1.Enable mod_env
> > 2.add lines like: setenv ORACLE_HOME /path/
> > 3.restart apache
> > I am not quite sure about step 2. What is the
> variable ORACLE_HOME and
> > the "path" refer to? In my case I am using
> Postgresql, so what should
> > be the environment variable's name ? and what will
> be the path it is
> > related to ? Will the path mean the folder has the
> postgresql driver
> > installed or the folder that the postgresql
> installed ?
> We Wei,
> If you are using Postgresql you don't need to set
> the ORACLE_HOME environment
> variable. That was just one example of the sort of
> stuff you might need to do.
> You likely don't need to set any environment
> variables for Postgres.
> You do need to ensure that ODBC access to the
> database works for the user that
> MapServer will run as (nobody, www-data, or an
> apache user or something like that).
> You might test this by running the unix odbc client
> as the web user.
> eg.
> su
> Password: <root password>
> su - www-data
> isql <your_dsn>
> Or it may work differently for you. The point is,
> it is up to you to first
> ensure that ODBC access is working before you start
> using OGR and MapServer.
> Best regards,
> I set the clouds in motion - turn up | Frank
> Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows |
> http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
__________________________________
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online.
http://taxes.yahoo.com/filing.html
