[Mapserver-users] How to use mapserver to cascade arcims wms services
Bart van den Eijnden
bartvde at xs4all.nl
Sat Feb 7 11:54:39 EST 2004
Hi Larry,
first of all I think your wms_name is invalid, because it contains a
space. The wms_name is used to perform the WMS request. Secondly, you
should use 1 wms_format instead of 2 formats separated by commas (does
your ArcIMS server have a GIF license, if not use image/png).
Here I have a working example (BTW I am using the ESRI WMS connector 0.0.6
instead of the standard version delivered with ArcIMS 4):
LAYER
CONNECTION
"http://myserver/ogcwms/servlet/com.esri.ogc.wms.WMSServlet?servicename=top50vector&SERVICE=WMS&VERSION=1.1.0&LAYERS=t50_vlakken_region&QUERY_LAYERS=t50_vlakken_region&FORMAT=image/png&transparent=true"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:28992 EPSG:4326"
"wms_onlineresource" "http://myserver/ogcwms/servlet/com.esri.ogc.wms.WMSServlet?servicename=top50vector&"
"wms_stylelist" ""
"wms_name" "top50vector_t50_vlakken_region"
"wms_title" "top 50 vector"
"wms_style_default_title" ""
"wms_style_default_legendurl" "0 0 "
"wms_server_version" "1.1.0"
"wms_formatlist" "image/jpeg,image/png"
"wms_format" "image/png"
"wms_boundingbox" "EPSG:28992 0 288007.5 288009 624000"
"wms_style" "default"
"wms_latlonboundingbox" "2.68506 49.54247 7.75847 54.61588"
END
NAME "top50vector_t50_vlakken_region"
PROJECTION
"init=epsg:28992"
END
SIZEUNITS PIXELS
STATUS ON
DUMP TRUE
MINSCALE 0
MAXSCALE 50000
TEMPLATE "blank.html"
TOLERANCE 0
TOLERANCEUNITS PIXELS
TYPE RASTER
UNITS METERS
END
Best regards,
Bart
On Fri, 06 Feb 2004 16:47:18 -0330, Larry Nolan <larrynolan at gov.nl.ca>
wrote:
> I have a group of geological surveys which have arcims web mapping
> servers with tons of geological information. I would like to use
> mapserver to act as a one stop connection to each of those servers in a
> client. I have mapserver 4.0 working fine serving ogc wms map services.
> Does anyone have the syntax to connect to an esri arcims service which
> has the wms connector turned on.
> I get a a general service exception when I try to connect to this layer.
> LAYER
> NAME "NAD27LandBase"
> TYPE RASTER
> STATUS ON
> CONNECTION
> "http://gis.geosurv.gov.nf.ca/servlet/com.esri.wms.Esrimap?servicename=NAD27_Basemap"
> CONNECTIONTYPE WMS
> METADATA
> "wms_name" "Base Map"
> "wms_formatlist" "image/gif,image/png,image/jpeg,image/wbmp"
> "wms_format" "image/gif,image/png"
> END
> PROJECTION
> "proj=tmerc"
> "lat_0=0.0"
> "lon_0=-59.5"
> "k=0.998"
> "x_0=0.0"
> "y_0=1000000.0"
> "ellps=clrk66"
> "units=m"
> "no_defs"
> END
> END
> thanks
> Larry Nolan
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
