[Fwd: Re: [Mapserver-users] erro : TIFFMergeFieldInfo]
Daniel Morissette
dmorissette at dmsolutions.ca
Mon Feb 9 14:58:53 EST 2004
-------- Original Message --------
Subject: Re: [Mapserver-users] erro : TIFFMergeFieldInfo
Date: Mon, 09 Feb 2004 13:55:36 -0300
To: Daniel Morissette <dmorissette at dmsolutions.ca>
References: <1076330073.2169.5.camel at Pegasus.localdomain>
<402796CE.3070505 at dmsolutions.ca>
Daniel Morissette escreveu:
> It seems that TIFFMergeFieldInfo is available only in libtiff v3.6.1
> and up.
> But anyway, GDAL comes with its own built-in TIFF, so if you compile
> with GDAL, you should disable the native MapServer TIFF support using
> --without-tiff. That should take care of the error that you get as well.
> Daniel
I have the same error, but in the compilation of libgeotiff, when I try
./bin/makegeo ( how recommended to test the compilation ), I got the
error, and I'm using the recommended version by libgeotiff of the
libtiff library ! ! !
Can be a bug? Or I miss any parameter?
This is my configures:
[root at valhala tiff-v3.6.1]# ./configure
[root at valhala libgeotiff-1.2.1]# ./configure
--with-libtiff=/usr/local/lib/ --with-jpeg=/usr/local/lib/
The Error:
[root at valhala libgeotiff-1.2.1]# ./bin/makegeo
./bin/makegeo: relocation error: /usr/local/lib/libgeotiff.so: undefined
symbol: TIFFMergeFieldInfo
Any idea of what is happen?
[]'s
by qoelheX
