[Fwd: Re: [Mapserver-users] erro : TIFFMergeFieldInfo]
Mon Feb 9 16:46:29 EST 2004
> I have the same error, but in the compilation of libgeotiff, when I try
> ./bin/makegeo ( how recommended to test the compilation ), I got the
> error, and I'm using the recommended version by libgeotiff of the
> libtiff library ! ! !
> Can be a bug? Or I miss any parameter?
> This is my configures:
> [root at valhala tiff-v3.6.1]# ./configure
> [root at valhala libgeotiff-1.2.1]# ./configure
> --with-libtiff=/usr/local/lib/ --with-jpeg=/usr/local/lib/
> The Error:
> [root at valhala libgeotiff-1.2.1]# ./bin/makegeo
> ./bin/makegeo: relocation error: /usr/local/lib/libgeotiff.so: undefined
> symbol: TIFFMergeFieldInfo
> Any idea of what is happen?
> []'s
> by qoelheX
The problem is that, while you have "built" against the new libtiff in
/usr/local, at runtime the old search rules are used to find a libtiff.so
and it is picking up /usr/lib/libtiff.so.  You need to adjust this using
the LD_LIBRARY_PATH environment variable or by adjusting ld.conf.
eg.
setenv LD_LIBRARY_PATH /usr/local/lib
This is a very common issue with all sorts of libraries.  I don't know a
good description to point you at though.
Best regards,
