[Fwd: Re: [Mapserver-users] erro : TIFFMergeFieldInfo]
qoelheX
qoelhex at cttmar.univali.br
Mon Feb 9 18:14:33 EST 2004
Frank Warmerdam wrote:
> Hi,
> The problem is that, while you have "built" against the new libtiff in
> /usr/local, at runtime the old search rules are used to find a libtiff.so
> and it is picking up /usr/lib/libtiff.so. You need to adjust this using
> the LD_LIBRARY_PATH environment variable or by adjusting ld.conf.
> eg.
> setenv LD_LIBRARY_PATH /usr/local/lib
> This is a very common issue with all sorts of libraries. I don't know a
> good description to point you at though.
> Best regards,
BINGO ! ! ! ! !
Thanks :D
by qoelheX
