[Mapserver-users] dBox, Rosa, Macs, mapscript
Liz Godwin
godwinl at agr.gc.ca
Thu Feb 12 11:00:18 EST 2004
Hello List,
I need to use a different means for navigation than Rosa for my
applications. It does not seem to work on Mac computers.
At the moment I am working on a PHPMapscript application, however I
will have to change some CGI apps later.
With my PHP application, I have been looking into the dBox example as
an alternative to Rosa. The reason I liked these examples is that I can
zoom into a rectangle and get a nice rubber band box. The problem with
dBox is that it is complicated and I need only a small subset of the
code, but before diving into it I thought I would ask the list first..
can I use dBox without the mapserv object? All I want from it is to
allow me to draw a box (or simple click) on a map image and then return
the coordinates in pixels.
Should I bother with dBox? Are there more simple examples out there?
I'm sure this isn't hard to code, but I would rather not start over if I
can help it.
On the same note, I am hoping to exploit the CBE javascript library so
I don't have to fret over cross-browser issues.
Thanks for the help,
Liz Godwin
