[Mapserver-users] dBox, Rosa, Macs, mapscript
Zak James
zak-ms at hoppsan.org
Thu Feb 12 16:50:29 EST 2004
I'm pretty sure the problem with ROSA on macs is that it requires
liveconnect, a mechanism for java to communicate with javascript.
It used to be that it wasn't available at all on the mac platform, but
Apple released a new version of Safari (1.2) last week that implements
it for their Java 1.4.2 VM. I tested it locally and it allows ROSA to
work.
Of course, if your clients don't have the latest version of OS X, it's
not a great solution. Have you considered using Chameleon
(www.maptools.org)? It provides a DHTML rubber band that works fine in
most mac browsers.
zak
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
On Feb 12, 2004, at 11:00 AM, Liz Godwin wrote:
> Hello List,
> I need to use a different means for navigation than Rosa for my
> applications. It does not seem to work on Mac computers.
> At the moment I am working on a PHPMapscript application, however I
> will have to change some CGI apps later.
> With my PHP application, I have been looking into the dBox example as
> an alternative to Rosa. The reason I liked these examples is that I
> can
> zoom into a rectangle and get a nice rubber band box. The problem with
> dBox is that it is complicated and I need only a small subset of the
> code, but before diving into it I thought I would ask the list first..
> can I use dBox without the mapserv object? All I want from it is to
> allow me to draw a box (or simple click) on a map image and then return
> the coordinates in pixels.
> Should I bother with dBox? Are there more simple examples out there?
> I'm sure this isn't hard to code, but I would rather not start over if
> I
> can help it.
> On the same note, I am hoping to exploit the CBE javascript library so
> I don't have to fret over cross-browser issues.
> Thanks for the help,
> Liz Godwin
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
