[Mapserver-users] Question - EROS NED service
Brian Fischer bfischer at houstonengineeringinc.com
Fri Feb 13 12:58:45 EST 2004
You are absolutely right.  Thanks for clarifying.  Sorry about any
confusion.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
-----Original Message-----
Sent: Friday, February 13, 2004 11:47 AM
To: Brian Fischer; Bryan Carlson; mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Question - EROS NED service
Brian -
The layer you describe in your example isn't an "ArcIMS layer" - it's a
WMS layer, although it may be rendered by an ArcIMS server.  Bryan, what
Brian is saying is that the USGS NED shaded relief service is available
as a WMS service, not just an ArcIMS service, and it can be easily used
in MapServer using just the method Brian describes.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
From: Brian Fischer [mailto:bfischer at houstonengineeringinc.com]
Sent: Friday, February 13, 2004 12:27 PM
To: Bryan Carlson; mapserver-users at lists.gis.umn.edu
Bryan,
We use this ArcIMS layer in one of our MapServer 3.6 applications.  Here
is the WMS Layer Definition:
LAYER
     NAME "usgselev"
     METADATA
       "wms_title" "US_NED_Shaded_Relief"
       "wms_srs" "epsg:4326"
       "wms_connectiontimeout" "1000"
     END
     TYPE RASTER
     STATUS OFF
     CONNECTIONTYPE WMS
     CONNECTION
"http://gisdata.usgs.net/servlet/com.esri.wms.Esrimap?ServiceName=USGS_W
MS_NED&VERSION=1.0.0&REQUEST=map&Layers=US_NED_Shaded_Relief&SRS=EPSG:43
26&REASPECT=false&Format=gif"
     PROJECTION
       "init=epsg:4326"
     END
   END #layer usgselev
Hope this helps you out,
Brian
Brian Fischer
Maple Grove, MN
(763) 493-4522
Sent: Friday, February 13, 2004 10:51 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Question - EROS NED service
I was wondering if Mapserver is able to support ArcIMS services?  I am
interested in using the EROS NED service which requires me to connect to
'http://gisdata.usgs.net'.  I was told I need to use arcMap, it would be
wonderful if I could use Mapserver as I like what I see so far.
Thank you,
-brude
fsbrc at uaf.edu
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
