[Mapserver-users] Question - EROS NED service
Bryan Carlson
fsbrc at uaf.edu
Sat Feb 14 17:56:05 EST 2004
Thank you both for the help. You have saved me from doing a lot of
meaningless research.
It's great the see the community has members like you two.
Hope you're having a great valentines day. Something that I found interesting
(and has nothing to do with GIS:
http://www.economist.com/printedition/displayStory.cfm?Story_ID=2424049), the
science of love. Always good stuff.
-bryan
>===== Original Message From "Brian Fischer"
<bfischer at houstonengineeringinc.com> =====
>You are absolutely right. Thanks for clarifying. Sorry about any
>confusion.
>Brian Fischer
>Houston Engineering, Inc.
>Maple Grove, MN
>(763) 493-4522
>-----Original Message-----
>From: Ed McNierney [mailto:ed at topozone.com]
>Sent: Friday, February 13, 2004 11:47 AM
>To: Brian Fischer; Bryan Carlson; mapserver-users at lists.gis.umn.edu
>Subject: RE: [Mapserver-users] Question - EROS NED service
>Brian -
>The layer you describe in your example isn't an "ArcIMS layer" - it's a
>WMS layer, although it may be rendered by an ArcIMS server. Bryan, what
>Brian is saying is that the USGS NED shaded relief service is available
>as a WMS service, not just an ArcIMS service, and it can be easily used
>in MapServer using just the method Brian describes.
> - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com / Maps a la carte, Inc.
>73 Princeton Street, Suite 305
>North Chelmsford, MA 01863
>ed at topozone.com
>(978) 251-4242
>From: Brian Fischer [mailto:bfischer at houstonengineeringinc.com]
>Sent: Friday, February 13, 2004 12:27 PM
>To: Bryan Carlson; mapserver-users at lists.gis.umn.edu
>Bryan,
>We use this ArcIMS layer in one of our MapServer 3.6 applications. Here
>is the WMS Layer Definition:
>LAYER
> NAME "usgselev"
> METADATA
> "wms_title" "US_NED_Shaded_Relief"
> "wms_srs" "epsg:4326"
> "wms_connectiontimeout" "1000"
> END
> TYPE RASTER
> STATUS OFF
> CONNECTIONTYPE WMS
> CONNECTION
>"http://gisdata.usgs.net/servlet/com.esri.wms.Esrimap?ServiceName=USGS_W
>MS_NED&VERSION=1.0.0&REQUEST=map&Layers=US_NED_Shaded_Relief&SRS=EPSG:43
>26&REASPECT=false&Format=gif"
> PROJECTION
> "init=epsg:4326"
> END
> END #layer usgselev
>Hope this helps you out,
>Brian
>Brian Fischer
>Maple Grove, MN
>(763) 493-4522
>From: Bryan Carlson [mailto:fsbrc at uaf.edu]
>Sent: Friday, February 13, 2004 10:51 AM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] Question - EROS NED service
>I was wondering if Mapserver is able to support ArcIMS services? I am
>interested in using the EROS NED service which requires me to connect to
>'http://gisdata.usgs.net'. I was told I need to use arcMap, it would be
>wonderful if I could use Mapserver as I like what I see so far.
>Thank you,
>-brude
>fsbrc at uaf.edu
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
