[Mapserver-users] QueryByRectangle problem (PostGIS layer,
PHP/MapScript)
Paul Ramsey
pramsey at refractions.net
Mon Feb 16 10:44:08 EST 2004
Downgrading to PgSQL 7.3 will fix this.
Upgrading your mapserver to the CVS version (4.0 or 4.1) will also fix
it.
It is a change in cursor behavior in PostgreSQL 7.4. (They must now be
explicitly closed at the end of a transaction.)
On Monday, February 16, 2004, at 07:16 AM, Vojtech Honzik wrote:
> I have following problem:
> When I do a query by point, everything goes ok as well as query by
> rectangle querying only one feature.
> When querying multiple features, error
> WARNING: there is already a transaction in progress
> ERROR: cursor "mycursor" already exists
> occurs.
> I have been told that this is caused by that fact that MapsCript does
> not
> close connections after itself. The solution should be adding
> explicit "CLOSE cursor" to mappostgis.h
> but - I am running the Mapserver on windows platform and I was not
> able to
> compile PHP MapScript module with the fix (because I don't have VC++
> compiler as suggested)
> I'd like to ask:
> 1. What component "downgrade" could fix this error?
> 2. If you would prefer patch and recompilation, is there a way to
> produce
> php_mapscript.dll using g++?
> 3. Does there exist another way how to solve this multiple query
> problem?
> Truly yours,
> Vojtech Honzik
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
