[Mapserver-users] Problem: processTemplate()
Janett Jahn
jjahn at et-inf.fho-emden.de
Wed Feb 18 06:23:04 EST 2004
I have a problem when I am using the processTemplate() function from perl
mapscript.
The function returns :
Type error in argument 3 of mapObj_processTemplate. Expected _p_pchar at
./myfile.pl line 42.
my code :
my @tnames = keyes(%tags);
my @tvalues = values(%tags);
my $temp =
$map->processTemplate($mapscript::MS_TRUE,\@tnames,\@tvalues,$#tnames +1);
I know that there was the same question on 09.08.2002 and I read the answer
(10.08.2002) too.
I installed SWIG version 1.1 and append the lines to typemaps.i .
When I run "swig -shadow -perl5 mapscript.i" I get many errors in mapscript.i.
Then I removed SWIG version 1.1 and installed the newest (1.3.21).
I appended these lines and run swig again. Then I got 2 warnings :
"Depracated typemap feature ($source/$target)..."
I changed the lines as follows :
%module argv
// This tells SWIG to treat char ** as a special case
%typemap(perl5,in) char ** {
AV *tempav;
I32 len;
int i;
SV **tv;
if (!SvROK($input))
croak("$input is not a reference.");
if (SvTYPE(SvRV($input)) != SVt_PVAV)
croak("$input is not an array.");
tempav = (AV*)SvRV($input);
len = av_len(tempav);
$1 = (char **) malloc((len+2)*sizeof(char *));
for (i = 0; i <= len; i++) {
tv = av_fetch(tempav, i, 0);
$1[i] = (char *) SvPV(*tv,PL_na);
$1[i] = 0;
// This cleans up our char ** array after the function call
%typemap(perl5,freearg) char ** {
free($input);
// Creates a new Perl array and places a char ** into it
%typemap(perl5,out) char ** {
AV *myav;
SV **svs;
int i = 0,len = 0;
/* Figure out how many elements we have */
while ($1[len])
len++;
svs = (SV **) malloc(len*sizeof(SV *));
for (i = 0; i < len ; i++) {
svs[i] = sv_newmortal();
sv_setpv((SV*)svs[i],$1[i]);
myav = av_make(len,svs);
free(svs);
$result = newRV((SV*)myav);
sv_2mortal($result);
After that I run swig again and there were no errors or warnings and so I
compiled the perl- mapscript.
But I still get the same error, when I try to run my perlsript.
Can someone help me ???
(sorry for my bad english)
This mail sent through IMP: http://horde.org/imp/
