[Mapserver-users] Oracle layer - labelling, querying and ORA spatial index problems
Martin Tomko
tomko at gku.sk
Thu Feb 19 10:53:56 EST 2004
Hi list!
I finally got my sample Oracle layer working. I am still encountering a
few errors:
1. I am getting an error:
"msOracleSpatialLayerGetShape(): OracleSpatial error. Function not
implemented yet"
when I try to make a query on the layer.
2. I am also not able to get the labels, based on some attributes of my
spatial table, displayed.
3. A different one - this is more an Oracle problem, but I am getting
desperate as I cannot get it solved... I am getting this errors while
trying to make a spatial index on my table. No, I did not forget to make
an entry in the metadata... SQL:
CREATE TABLE bodysps (CBODU NUMBER PRIMARY KEY,NAZOV VARCHAR (32),X
NUMBER,Y NUMBER,Z NUMBER,TOPO VARCHAR (32),shape MDSYS.SDO_GEOMETRY);
commit;
INSERT INTO bodysps
VALUES(1,'GANP',-329391,-1201080,700,'1005.GIF',MDSYS.SDO_GEOMETRY(2001,
NULL,MDSYS.SDO_POINT_TYPE(-329391,-1201080,NULL),NULL,NULL));
INSERT INTO bodysps
VALUES(2,'BBYS',-417261,-1226741,444,'1005.GIF',MDSYS.SDO_GEOMETRY(2001,
NULL,MDSYS.SDO_POINT_TYPE(-417261,-1226741,NULL),NULL,NULL));
INSERT INTO bodysps
VALUES(3,'MOPI',-558922,-1256757,535,'1005.GIF',MDSYS.SDO_GEOMETRY(2001,
NULL,MDSYS.SDO_POINT_TYPE(-558922,-1256757,NULL),NULL,NULL));
-- metadata update
INSERT INTO USER_SDO_GEOM_METADATA
VALUES (
'body',
'shape',
MDSYS.SDO_DIM_ARRAY(
MDSYS.SDO_DIM_ELEMENT('X', 0, -591445, 0.005),
MDSYS.SDO_DIM_ELEMENT('Y', 0, -1373146, 0.005),
MDSYS.SDO_DIM_ELEMENT('Z', 0, 1000, 0.005)),
NULL -- SRID
SQL> CREATE INDEX bodysps_idx
2 ON bodysps(shape)
3 INDEXTYPE IS MDSYS.SPATIAL_INDEX;
ERROR v riadku 1:
ORA-29855: error occurred in the execution of ODCIINDEXCREATE routine
ORA-13249: Error executing stmt: begin
mdsys.prvt_idx.execute_insert(NULL,
NULL, ' VALUES (''MDSYS'',''MDIDX_INIT'', 0, 0, 64, -1,
NLS_UPPER(''MDRT_7992$''), ''BODYSPS_IDX'', 1, ''MDSYS'', ''"SHAPE"'',
0, 0, 3,
0, ''DEFAULT'', ''DEFAULT'', NULL,NULL, NULL, NULL, NULL, NULL, NULL, 2,
''DEFAULT'', 10, NULL, NULL, NULL, NULL, ''FALSE'', ''VALID'', NULL)',
NULL);
end;
ORA-13249: Error in Spatial index: insert to metadata failed
ORA-29400: data cartridge error
ORA-00913: too many values
ORA-06512: at "MDSYS.PRVT_IDX", line 5
ORA-06512: at line 1
ORA-06512: at "MDSYS.SDO_INDEX_METHOD_9I", line 7
