[Mapserver-users] Multiple Layer Itemqueries?
David Fawcett
David.Fawcett at state.mn.us
Thu Feb 19 15:50:38 EST 2004
Let me re-frame this to see if anyone has any creative answers.
I am using CGI MS. I have a shapefile with county polygons. Through a
URL call, I would like to display selected polygons drawn with colors
that reflect of two possible classes. The poly IDs have to be passed in
through the URL (like an item query). The mapfile could contain one
layer with two classes or two layers with only one class.
The data is dynamic and not stored in the shape file, it comes from an
Access database. The final MS image is being requested through a
<cfhttp> tag in ColdFusion. An itemquery for a selected list of polys
works great through this method.
Here is a story problem example.... ; )
In the past 5 years, about a third of the counties in this state held
interim elections. Display the polys for the counties that held interim
elections, and color them red if they went Republican and blue if they
went Democratic.
Any ideas?
David J. Fawcett
MN Office of Environmental Assistance
>>> "David Fawcett" <David.Fawcett at state.mn.us> 2/19/2004 9:02:46 AM
Is it possible to perform two itemnqueries in the same request?
Something like:
http://0.0.0.0/cgi-bin/ms4/mapserv.exe?map=e%3A%5Cweb%2Fsc%5Cmulti.map&mode=itemnquery&qlayer=sub&qitem=FIPS&qstring=('[FIPS]'+IN+'27001,27003,27005')&qlayer=log&qitem=FIPS&qstring=('[FIPS]'+IN+'27007,27009,27011')"
I have a map file with two layers that both reference the same MN
counties poly shapefile. I have classed each layer so one is red and
the other is blue. And, I am using STYLE selected in my querymap
object.
It works, but it appears that the second itemnquery overwrites the
first one in the URL string. Is it possible to get the selected items
from each layer to show up in the same image?
Here is the Map Snippet:
QUERYMAP
SIZE 150 150
STATUS ON
STYLE SELECTED
#COLOR 255 204 102
END
LAYER
NAME log
STATUS ON
TYPE POLYGON
DATA score
TEMPLATE "selectcounty.html"
FOOTER "selectcountyfoot.html"
CLASS
COLOR 255 0 0
OUTLINECOLOR 181 181 181
END
END
LAYER
NAME sub
STATUS ON
TYPE POLYGON
DATA score
CLASS
COLOR 255 204 102
END
END
David J. Fawcett
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
