[Mapserver-users] Perl/Python/Ruby mapscript development documentation
Lowell Filak
lfilak at medinaco.org
Wed Feb 25 08:38:05 EST 2004
Thank you to all the developers.
Lowell
The following message was sent by Sean Gillies <sgillies at frii.com> on
Tue, 24 Feb 2004 10:19:40 -0700.
> Hi,
> Following the example of the PHP-mapscript developers, we are now
> maintaining
> documentation for the development mapscript in a text file. In CVS in
> can be
> found at mapscript/doc/mapscript.txt. Language-specific appendices
> will be
> at mapscript/doc/python.txt etc. This new documentation fills the same
> role as
> the README file under mapscript/php3. Is a work in progress, but I'm
> chipping
> away at it every day and we'll be caught up with the current state of
> the
> development code soon.
> We are trying out restructured text as a file format. It provides just
> enough
> structure that it can be parsed and rendered into XML or HTML. During
> the
> evaluation of mapscript.txt I will be regularly generating HTML from
> the text source
> and putting it up at
> http://users.frii.com/sgillies/examples/mapscript.html
> Links to the original text source and documentation about reST and
> links to
> download of reST tools are at the bottom of the page. If users
> appreciate this
> development documentation, I'll work the generation of HTML docs into
> the mapserver
> nightly build.
> If you have considerations that you'd like to add to Bugzilla regarding
> the
> development docs, join the discussion here
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=576
> or discuss here on the list and I'll try to summarize on Bugzilla.
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
