[Mapserver-users] Perl/Python/Ruby mapscript development documentation
Sean Gillies
sgillies at frii.com
Wed Feb 25 12:54:44 EST 2004
Is that a statement of complete approval? Did you check the underlying
mapscript.txt file? Does it look like something you'd use instead of
referring to the PHP readme?
Sean
On Feb 25, 2004, at 6:38 AM, Lowell Filak wrote:
> Thank you to all the developers.
> Lowell
> The following message was sent by Sean Gillies <sgillies at frii.com> on
> Tue, 24 Feb 2004 10:19:40 -0700.
>> Hi,
>> Following the example of the PHP-mapscript developers, we are now
>> maintaining
>> documentation for the development mapscript in a text file. In CVS in
>> can be
>> found at mapscript/doc/mapscript.txt. Language-specific appendices
>> will be
>> at mapscript/doc/python.txt etc. This new documentation fills the
>> same
>> role as
>> the README file under mapscript/php3. Is a work in progress, but I'm
>> chipping
>> away at it every day and we'll be caught up with the current state of
>> the
>> development code soon.
>> We are trying out restructured text as a file format. It provides
>> just
>> enough
>> structure that it can be parsed and rendered into XML or HTML. During
>> the
>> evaluation of mapscript.txt I will be regularly generating HTML from
>> the text source
>> and putting it up at
>> http://users.frii.com/sgillies/examples/mapscript.html
>> Links to the original text source and documentation about reST and
>> links to
>> download of reST tools are at the bottom of the page. If users
>> appreciate this
>> development documentation, I'll work the generation of HTML docs into
>> the mapserver
>> nightly build.
>> If you have considerations that you'd like to add to Bugzilla
>> regarding
>> the
>> development docs, join the discussion here
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=576
>> or discuss here on the list and I'll try to summarize on Bugzilla.
>> cheers,
>> Sean
>> Sean Gillies
>> sgillies at frii dot com
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
