[Mapserver-users] Map Server compile problem
Eric Wright
eric.linux at shaw.ca
Wed Feb 25 22:27:26 EST 2004
Thank you for your help Frank,
Before I looked through the make file I had changed the ./configure to use the --without-tiff parameter, after which, runnning the make worked.
Thanks again, Eric
----- Original Message -----
Date: Wednesday, February 25, 2004 3:38 pm
Subject: Re: [Mapserver-users] Map Server compile problem
> E Wright wrote:
> > Map Server compile problem.
> > Good evening, I am trying to install the MapServer using the
> following
> > configure:
> > ./configure --with-gd=/usr/software/mapServer/gd-2.0.21
> > --with-tiff=/usr/software/mapServer/tiff-v3.6.1
> > --with-proj=/usr/software/mapServer/proj-4.4.7
> > --with-ogr=/usr/local/bin/gdal-config
> > --with-gdal=/usr/local/bin/gdal-config
> > --with-postgis=/usr/local/pgsql/include/pg_config --with-wfs
> > --with-curl=/usr/software/mapServer/curl-7.10.8/curl-config
> > This seems to run fine but when I try to run the make command I
> get the
> > following error:
> > gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
> > -DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_WFS_SVR -DUSE_TIFF -
> DUSE_JPEG
> > -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_OGR
> > -DUSE_GDAL -DUSE_POSTGIS -I/usr/software/mapServer/gd-2.0.21
> > -I/usr/software/mapServer/proj-4.4.7/src
> > -I/usr/software/mapServer/tiff-v3.6.1/libtiff -
> I/usr/local/include
> > -I/usr/local/include -I maptemplate.c -o maptemplate.o
> > gcc: no input files
> > make: *** [maptemplate.o] Error 1
> > I am fairly new to using Linux so I am not always too sure what
> > something is trying to tell me.
> > Any help that anyone can provide will be greatly appreciated.
> E,
> I think the problem is that "-I maptemplate.c" is causing the
> maptemplate.cfilename to be "eaten" as part of the -I directive.
> Try editing your
> Makefile, and searching for where a -I directive is setup with no
> argumenttext. Then remove the -I.
> This shouldn't happen of course. Your configure line looks ok. If
> you can
> report which macro was assigned this value we might be able to make
> theconfigure more bulletproof.
> PS. There isn't really that much benefit to having TIFF support
> configuredin directly if you are also using GDAL. You might want
> to change
> --with-tiff=/usr/software/mapServer/tiff-v3.6.1 to --without-tiff.
> TIFFfiles will still be supported, just through GDAL.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.comlight and sound - activate the windows |
> http://pobox.com/~warmerdamand watch the world go round - Rush |
> Geospatial Programmer for Rent
