[Mapserver-users] Map Server compile problem
Eric Wright
eric.linux at shaw.ca
Wed Feb 25 22:35:37 EST 2004
Please ignore my last email, it has been one of those days...
I found the following in the make file:
# Optional PostGIS Support. See http://postgis.refractions.net/
POSTGIS= -DUSE_POSTGIS
POSTGIS_LIB= -L -lpq
POSTGIS_INC= -I
and edited it to read:
#POSTGIS_INC= -I
Which lead to the following list (long) of errors:
mappostgis.c:17:22: libpq-fe.h: No such file or directory
mappostgis.c:24: error: syntax error before "PGconn"
mappostgis.c:24: warning: no semicolon at end of struct or union
mappostgis.c:26: error: syntax error before '*' token
mappostgis.c:26: warning: type defaults to `int' in declaration of `query_result'
mappostgis.c:26: warning: data definition has no type or storage class
mappostgis.c:30: error: syntax error before '}' token
mappostgis.c:30: warning: type defaults to `int' in declaration of `msPOSTGISLayerInfo'
mappostgis.c:30: warning: data definition has no type or storage class
mappostgis.c:44: error: syntax error before '*' token
mappostgis.c:45: warning: return type defaults to `int'
mappostgis.c:49: error: syntax error before "msPOSTGISLayerInfo"
mappostgis.c: In function `setPostGISLayerInfo':
mappostgis.c:51: error: `layer' undeclared (first use in this function)
mappostgis.c:51: error: (Each undeclared identifier is reported only once
mappostgis.c:51: error: for each function it appears in.)
mappostgis.c:51: error: `postgislayerinfo' undeclared (first use in this function)
mappostgis.c: In function `msPOSTGISLayerOpen':
mappostgis.c:183: error: `layerinfo' undeclared (first use in this function)
mappostgis.c:203: error: syntax error before ')' token
mappostgis.c:210: warning: implicit declaration of function `PQconnectdb'
mappostgis.c:212: warning: implicit declaration of function `PQstatus'
mappostgis.c:212: error: `CONNECTION_BAD' undeclared (first use in this function)
mappostgis.c:215: warning: implicit declaration of function `PQerrorMessage'
mappostgis.c:221: warning: implicit declaration of function `PQsetNoticeProcessor'
mappostgis.c: At top level:
mappostgis.c:291: error: syntax error before "PGresult"
mappostgis.c: In function `prep_DB':
mappostgis.c:293: error: `PGresult' undeclared (first use in this function)
mappostgis.c:293: error: `result' undeclared (first use in this function)
mappostgis.c:301: error: `layerinfo' undeclared (first use in this function)
mappostgis.c:305: error: `layer' undeclared (first use in this function)
mappostgis.c:320: error: `geom_table' undeclared (first use in this function)
mappostgis.c:361: error: `geom_column' undeclared (first use in this function)
mappostgis.c:381: error: `rect' undeclared (first use in this function)
mappostgis.c:438: warning: implicit declaration of function `PQexec'
mappostgis.c:439: warning: implicit declaration of function `PQresultStatus'
mappostgis.c:439: error: `PGRES_COMMAND_OK' undeclared (first use in this function)
mappostgis.c:444: warning: implicit declaration of function `PQclear'
mappostgis.c:460: error: `sql_results' undeclared (first use in this function)
mappostgis.c:461: error: `query_string' undeclared (first use in this function)
mappostgis.c:491: warning: format argument is not a pointer (arg 4)
mappostgis.c: In function `msPOSTGISLayerWhichShapes':
mappostgis.c:526: error: `layerinfo' undeclared (first use in this function)
mappostgis.c:573: error: `PGRES_TUPLES_OK' undeclared (first use in this function)
mappostgis.c:577: warning: format argument is not a pointer (arg 4)
mappostgis.c: In function `msPOSTGISLayerClose':
mappostgis.c:599: error: `layerinfo' undeclared (first use in this function)
mappostgis.c:610: warning: implicit declaration of function `PQfinish'
mappostgis.c: In function `msPOSTGISLayerNextShape':
mappostgis.c:927: error: `layerinfo' undeclared (first use in this function)
mappostgis.c: In function `msPOSTGISLayerGetShapeRandom':
mappostgis.c:957: error: `layerinfo' undeclared (first use in this function)
mappostgis.c:993: warning: implicit declaration of function `PQntuples'
mappostgis.c:996: warning: implicit declaration of function `PQgetvalue'
mappostgis.c:1030: warning: implicit declaration of function `PQgetlength'
mappostgis.c:1021: warning: enumeration value `MS_LAYER_GRATICULE' not handled in switch
mappostgis.c: In function `msPOSTGISLayerGetShape':
mappostgis.c:1080: error: `PGresult' undeclared (first use in this function)
mappostgis.c:1081: error: `layerinfo' undeclared (first use in this function)
mappostgis.c:1133: warning: assignment makes pointer from integer without a cast
mappostgis.c:1134: error: `PGRES_COMMAND_OK' undeclared (first use in this function)
mappostgis.c:1144: warning: assignment makes pointer from integer without a cast
mappostgis.c:1158: warning: assignment makes pointer from integer without a cast
mappostgis.c:1164: warning: format argument is not a pointer (arg 4)
mappostgis.c:1178: warning: assignment makes pointer from integer without a cast
mappostgis.c:1179: error: `PGRES_TUPLES_OK' undeclared (first use in this function)
mappostgis.c:1183: warning: format argument is not a pointer (arg 4)
mappostgis.c:1224: warning: enumeration value `MS_LAYER_GRATICULE' not handled in switch
mappostgis.c: In function `msPOSTGISLayerGetItems':
mappostgis.c:1279: error: `layerinfo' undeclared (first use in this function)
mappostgis.c:1288: error: `PGresult' undeclared (first use in this function)
mappostgis.c:1321: warning: assignment makes pointer from integer without a cast
mappostgis.c:1322: error: `PGRES_TUPLES_OK' undeclared (first use in this function)
mappostgis.c:1326: warning: format argument is not a pointer (arg 4)
mappostgis.c:1338: warning: implicit declaration of function `PQnfields'
mappostgis.c:1347: warning: implicit declaration of function `PQfname'
mappostgis.c:1347: warning: assignment makes pointer from integer without a cast
make: *** [mappostgis.o] Error 1
Thanks again for your help.
Eric
----- Original Message -----
Date: Wednesday, February 25, 2004 3:38 pm
Subject: Re: [Mapserver-users] Map Server compile problem
> E Wright wrote:
> > Map Server compile problem.
> > Good evening, I am trying to install the MapServer using the
> following
> > configure:
> > ./configure --with-gd=/usr/software/mapServer/gd-2.0.21
> > --with-tiff=/usr/software/mapServer/tiff-v3.6.1
> > --with-proj=/usr/software/mapServer/proj-4.4.7
> > --with-ogr=/usr/local/bin/gdal-config
> > --with-gdal=/usr/local/bin/gdal-config
> > --with-postgis=/usr/local/pgsql/include/pg_config --with-wfs
> > --with-curl=/usr/software/mapServer/curl-7.10.8/curl-config
> > This seems to run fine but when I try to run the make command I
> get the
> > following error:
> > gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
> > -DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_WFS_SVR -DUSE_TIFF -
> DUSE_JPEG
> > -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_OGR
> > -DUSE_GDAL -DUSE_POSTGIS -I/usr/software/mapServer/gd-2.0.21
> > -I/usr/software/mapServer/proj-4.4.7/src
> > -I/usr/software/mapServer/tiff-v3.6.1/libtiff -
> I/usr/local/include
> > -I/usr/local/include -I maptemplate.c -o maptemplate.o
> > gcc: no input files
> > make: *** [maptemplate.o] Error 1
> > I am fairly new to using Linux so I am not always too sure what
> > something is trying to tell me.
> > Any help that anyone can provide will be greatly appreciated.
> E,
> I think the problem is that "-I maptemplate.c" is causing the
> maptemplate.cfilename to be "eaten" as part of the -I directive.
> Try editing your
> Makefile, and searching for where a -I directive is setup with no
> argumenttext. Then remove the -I.
> This shouldn't happen of course. Your configure line looks ok. If
> you can
> report which macro was assigned this value we might be able to make
> theconfigure more bulletproof.
> PS. There isn't really that much benefit to having TIFF support
> configuredin directly if you are also using GDAL. You might want
> to change
> --with-tiff=/usr/software/mapServer/tiff-v3.6.1 to --without-tiff.
> TIFFfiles will still be supported, just through GDAL.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.comlight and sound - activate the windows |
> http://pobox.com/~warmerdamand watch the world go round - Rush |
> Geospatial Programmer for Rent
