[Mapserver-users] Can binary release of MapServer 4.0 for Windows able to manage ECW raster files?
Pericles Nacionales nacional at cbs.umn.edu
Thu Feb 26 18:24:31 EST 2004
Well, it should.  All the win32 binaries from the MapServer site are
compiled with ECW support (through GDAL).  However, I have note tested
them so I can't really say that it works.  But then again, I know some
people who use it and it works properly.  I bet you a pretty penny it's
got something to do with either your paths or your extents.  Is your shape
path a subdirectory of the directory containing your  mapfile?  Try adding
the full path to your ecw file, ie: DATA
"c:/some/directory/for/your/S21301.ecw" and quickly test it with this URL:
http://localhost/cgi-bin/mapserv.exe?map="c:/some/directory/for/your/mapfile.map&layer=S21301&mode=map
Does it work?  If not, check your extent.  Do you have an extra zero in
there somewhere? 500004?
Good luck!
-Perry
On Thu, 26 Feb 2004, Mario Servin wrote:
> Hi everybody. I am using   MapServer 4.0 and was able to manage shape and
> gif input formats. I failed to generate a layer with a ECW input file. More
> surprisingly I got no error. I just get a blank image!!!. I downloaded
> MapServer 4.0 binary realase but still i am not sure if it is prepared for
> managing this input format as the documentation I found did not refer to
> this version. If it (as I guess) can not manage ECW files, can anybody poitn
> me to a binary version for Windows that can? Thanks in advance.
> By the way here's my .map file, still it is possible I am missing something:
> # Start of map file
> NAME DEMO
> STATUS ON
> SIZE 600 600
> EXTENT 160597.5 6402017.5 500004 6682201
> UNITS METERS
> SHAPEPATH "Bariloche"
> IMAGECOLOR 255 255 255
> # you may need to change this to match your MapServer build
> IMAGETYPE GIF
> # Start of web interface definition (including WMS enabling metadata)
> WEB
>   HEADER demo_header.html
>   TEMPLATE demo.html
>   FOOTER demo_footer.html
>   MINSCALE 1
>   MAXSCALE 16000000000
>   IMAGEPATH "set in demo_init.html"
>   IMAGEURL "set in demo_init.html"
>   METADATA
>     WMS_TITLE "UMN MapServer Itasca Demo"
>     WMS_ABSTRACT "This is the UMN MapServer demonstration application for
> Itasca County located in north central Minnesota."
>     WMS_ACCESSCONSTRAINTS none
>     # change this value to match your setup
>     WMS_ONLINERESOURCE "http://mariolaptop/MyPages/itasca/demo_init.html"
>     WMS_SRS "EPSG:26915"
>   END
> END
> # Start of legend
> LEGEND
>   KEYSIZE 18 12
>   LABEL
>     TYPE BITMAP
>     SIZE MEDIUM
>     COLOR 0 0 89
>   END
>   STATUS ON
> END
> # Start of scalebar
> SCALEBAR
>   IMAGECOLOR 0 0 0
>   LABEL
>     COLOR 255 255 255
>     SIZE MEDIUM
>   END
>   STYLE 1
>   SIZE 300 10
>   COLOR 255 255 255
>   UNITS KILOMETERS
>   INTERVALS 5
>   TRANSPARENT TRUE
>   STATUS TRUE
> END
> # Start of symbol definitions (we're only using a few)
> SYMBOL
>   NAME 'circle'
>   TYPE ELLIPSE
>   POINTS 1 1 END
>   FILLED TRUE
> END
> #Satelital
> LAYER
>       NAME "S21301"
>       DATA S21301.ecw
>       TYPE RASTER
>       STATUS DEFAULT
> END
> END
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
