[Mapserver-users] Can binary release of MapServer 4.0 for Windows able to manage ECW raster files?
Mario Servin
mservin at tecnoaccion.com.ar
Fri Feb 27 08:38:51 EST 2004
Dear Pericles,
Thanks for your prompt answer. I tried your suggestion. There was no
error but still I get a blank image...... Someone told me I'd better
download version 4.1. I ampretty sure I have installed gdal tools to manage
ECW files but....
Regards,
Mario
----- Original Message -----
From: "Pericles Nacionales" <nacional at cbs.umn.edu>
To: "Mario Servin" <mservin at tecnoaccion.com.ar>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, February 26, 2004 8:24 PM
Subject: Re: [Mapserver-users] Can binary release of MapServer 4.0 for
Well, it should. All the win32 binaries from the MapServer site are
compiled with ECW support (through GDAL). However, I have note tested
them so I can't really say that it works. But then again, I know some
people who use it and it works properly. I bet you a pretty penny it's
got something to do with either your paths or your extents. Is your shape
path a subdirectory of the directory containing your mapfile? Try adding
the full path to your ecw file, ie: DATA
"c:/some/directory/for/your/S21301.ecw" and quickly test it with this URL:
http://localhost/cgi-bin/mapserv.exe?map="c:/some/directory/for/your/mapfile.map&layer=S21301&mode=map
Does it work? If not, check your extent. Do you have an extra zero in
there somewhere? 500004?
Good luck!
-Perry
On Thu, 26 Feb 2004, Mario Servin wrote:
> Hi everybody. I am using MapServer 4.0 and was able to manage shape and
> gif input formats. I failed to generate a layer with a ECW input file.
More
> surprisingly I got no error. I just get a blank image!!!. I downloaded
> MapServer 4.0 binary realase but still i am not sure if it is prepared for
> managing this input format as the documentation I found did not refer to
> this version. If it (as I guess) can not manage ECW files, can anybody
poitn
> me to a binary version for Windows that can? Thanks in advance.
> By the way here's my .map file, still it is possible I am missing
something:
> # Start of map file
> NAME DEMO
> STATUS ON
> SIZE 600 600
> EXTENT 160597.5 6402017.5 500004 6682201
> UNITS METERS
> SHAPEPATH "Bariloche"
> IMAGECOLOR 255 255 255
> # you may need to change this to match your MapServer build
> IMAGETYPE GIF
> # Start of web interface definition (including WMS enabling metadata)
> WEB
> HEADER demo_header.html
> TEMPLATE demo.html
> FOOTER demo_footer.html
> MINSCALE 1
> MAXSCALE 16000000000
> IMAGEPATH "set in demo_init.html"
> IMAGEURL "set in demo_init.html"
> METADATA
> WMS_TITLE "UMN MapServer Itasca Demo"
> WMS_ABSTRACT "This is the UMN MapServer demonstration application for
> Itasca County located in north central Minnesota."
> WMS_ACCESSCONSTRAINTS none
> # change this value to match your setup
> WMS_ONLINERESOURCE "http://mariolaptop/MyPages/itasca/demo_init.html"
> WMS_SRS "EPSG:26915"
> END
> END
> # Start of legend
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS ON
> END
> # Start of scalebar
> SCALEBAR
> IMAGECOLOR 0 0 0
> LABEL
> COLOR 255 255 255
> SIZE MEDIUM
> END
> STYLE 1
> SIZE 300 10
> COLOR 255 255 255
> UNITS KILOMETERS
> INTERVALS 5
> TRANSPARENT TRUE
> STATUS TRUE
> END
> # Start of symbol definitions (we're only using a few)
> SYMBOL
> NAME 'circle'
> TYPE ELLIPSE
> POINTS 1 1 END
> FILLED TRUE
> END
> #Satelital
> LAYER
> NAME "S21301"
> DATA S21301.ecw
> TYPE RASTER
> STATUS DEFAULT
> END
> END
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
