[Mapserver-users] mapscript - strange behavior
Sean Gillies sgillies at frii.com
Tue Jan 13 18:35:56 EST 2004
I don't see anything obviously wrong with your script.  I haven't been
testing your particular use case.  I will try to make the time to add
new tests to mapscript/python/tests/testMapScript.py and see if there
is a bug.
On Jan 13, 2004, at 3:30 PM, Christoph Spoerri wrote:
> Yes, I'm using mod_python but don't use a persistent mapObj (I assume
> you mean
> storing the object as session variable). I tried it, but it lead only
> to seg.
> faults.
> The reason for not using a predefined acetate layers is how my app is
> coded. I
> didn't want to change things around, and since the problem looks like
> a bug,
> and I was wondering if there's a solution. Also, I wasn't sure if I'm
> doing
> something wrong.
> Christoph
