[Mapserver-users] can't view 2 WMS layers(from 2 different servers)
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Thu Jul 1 16:59:02 EDT 2004
I set up two WMS mapfile server and installed Intereoperability Tools
for ArcGIS 8.x but I can't view the both layers together in ArcGIS ( one
over the other - one is a point layer and the other is polygon layer).
Here's the first mapfile:
1 --------------
MAP
NAME "wmsserver"
EXTENT -73.991 -33.751 -32.378 5.272
SHAPEPATH "C:/local/mapas/mapasBrasil/"
SIZE 600 400
IMAGECOLOR -1 -1 -1
IMAGETYPE PNG
OUTPUTFORMAT
NAME PNG
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE PC256
EXTENSION "png"
TRANSPARENT ON
END
PROJECTION
"init=epsg:4291"
END
WEB
METADATA
"wms_title" "Teste1"
"wms_onlineresource"
"http://localhost/cgi-bin/mapserv.exe?map=C:/local/web/testewms/wms1.map&"
"wms_srs" "EPSG:4291"
END
END
LAYER
NAME "estados"
PROJECTION
"init=epsg:4291"
END
METADATA
"wms_title" "Estados"
"wms_group_title" "Todos"
END
TRANSPARENCY 50
TYPE POLYGON
DATA "br_uf"
CLASS
COLOR 128 128 192
OUTLINECOLOR 0 0 0
END
DUMP TRUE
END
END
and here's the 2nd one:
2-----------
MAP
NAME "wmsserver"
SIZE 600 400
IMAGECOLOR -1 -1 -1
IMAGETYPE PNG
OUTPUTFORMAT
NAME PNG
DRIVER "GD/PNG"
IMAGEMODE PC256
EXTENSION "png"
TRANSPARENT ON
END
PROJECTION
"init=epsg:4291"
END
WEB
METADATA
"wms_title" "Teste2"
"http://localhost/cgi-bin/mapserv.exe?map=C:/local/web/testewms/wms2.map&"
END
END
SYMBOL
NAME 'ponto'
TYPE ELLIPSE
FILLED TRUE
POINTS
1 1
END
END
LAYER
DUMP TRUE
NAME "sedes"
PROJECTION
"init=epsg:4291"
END
METADATA
"wms_title" "Sedes"
END
TYPE POINT
DATA "br_sede"
TRANSPARENCY 50
CLASS
COLOR 255 0 0
OUTLINECOLOR 255 0 0
SYMBOL "ponto"
SIZE 2
END
END
END
in ArcGIS when I load
and
connection I can't view one over the other. only top layer appears.
what is wrong?
http://www.consultoria.eti.br
UIN: 303747254
Treinamento em UMN MapServer - http://www.consultoria.eti.br/ptbr/?menuoption=mapserver
I Encontro Nacional de Usuários MapServer - http://mapserver.cttmar.univali.br/encontro2004
Fórum MapServer Brasil - http://mapserver.cttmar.univali.br/forum
***Fim da Mensagem / End of Message ***
