[Mapserver-users] can't view 2 WMS layers(from 2 different
servers)
bartvde at xs4all.nl
Fri Jul 2 02:00:15 EDT 2004
Can you check which format ArcGIS is requesting, e.g. by logging the
GetMap URL? Maybe it is requesting the images in jpeg?
Best regards,
Bart
> Hi,
> I set up two WMS mapfile server and installed Intereoperability Tools
> for ArcGIS 8.x but I can't view the both layers together in ArcGIS ( one
> over the other - one is a point layer and the other is polygon layer).
> Here's the first mapfile:
> 1 --------------
> MAP
> NAME "wmsserver"
> EXTENT -73.991 -33.751 -32.378 5.272
> SHAPEPATH "C:/local/mapas/mapasBrasil/"
> SIZE 600 400
> IMAGECOLOR -1 -1 -1
> IMAGETYPE PNG
> OUTPUTFORMAT
> NAME PNG
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE PC256
> EXTENSION "png"
> TRANSPARENT ON
> END
> PROJECTION
> "init=epsg:4291"
> END
> WEB
> METADATA
> "wms_title" "Teste1"
> "wms_onlineresource"
> "http://localhost/cgi-bin/mapserv.exe?map=C:/local/web/testewms/wms1.map&"
> "wms_srs" "EPSG:4291"
> END
> END
> LAYER
> NAME "estados"
> PROJECTION
> "init=epsg:4291"
> END
> METADATA
> "wms_title" "Estados"
> "wms_group_title" "Todos"
> END
> TRANSPARENCY 50
> TYPE POLYGON
> DATA "br_uf"
> CLASS
> COLOR 128 128 192
> OUTLINECOLOR 0
> END
> DUMP TRUE
> END
> END
> and here's the 2nd one:
> 2-----------
> MAP
> NAME "wmsserver"
> SIZE 600 400
> IMAGECOLOR -1 -1 -1
> IMAGETYPE PNG
> OUTPUTFORMAT
> NAME PNG
> DRIVER "GD/PNG"
> IMAGEMODE PC256
> EXTENSION "png"
> TRANSPARENT ON
> END
> PROJECTION
> "init=epsg:4291"
> END
> WEB
> METADATA
> "wms_title" "Teste2"
> "http://localhost/cgi-bin/mapserv.exe?map=C:/local/web/testewms/wms2.map&"
> END
> END
> SYMBOL
> NAME 'ponto'
> TYPE ELLIPSE
> FILLED TRUE
> POINTS
> 1 1
> END
> END
> LAYER
> DUMP TRUE
> NAME "sedes"
> PROJECTION
> "init=epsg:4291"
> END
> METADATA
> "wms_title" "Sedes"
> END
> TYPE POINT
> DATA "br_sede"
> TRANSPARENCY 50
> CLASS
> COLOR 255 0
> OUTLINECOLOR 255 0
> SYMBOL "ponto"
> SIZE 2
> END
> END
> END
> in ArcGIS when I load
> and
> connection I can't view one over the other. only top layer appears.
> what is wrong?
> Eduardo Patto Kanegae
> http://www.consultoria.eti.br
> UIN: 303747254
> Treinamento em UMN MapServer -
> http://www.consultoria.eti.br/ptbr/?menuoption=mapserver
> I Encontro Nacional de Usuários MapServer -
> http://mapserver.cttmar.univali.br/encontro2004
> Fórum MapServer Brasil - http://mapserver.cttmar.univali.br/forum
