[Mapserver-users] SLD and mapserver...
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Fri Jul 2 16:00:05 EDT 2004
> -----Original Message-----
> From: William White [mailto:william at javamonkeys.co.uk]
> Sent: Friday, July 02, 2004 2:34 PM
> To: Kralidis,Tom [Burlington]
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] SLD and mapserver...
> Tom - you are the man...
> Thanks to your help, I am finally able to draw colours on
> maps!  Check
> it out:
> http://www.globalfinancemap.com/
Very nice -- way to go!  It's great to see these approaches used in an
application such as this.
> I'm currently using the WorldGen,WorldPolitical layers at
> http://www2.dmsolutions.ca/cgi-bin/mswms_world.  If anyone
> has any other
> mapservers/layers they would suggest which might offer better images,
> yet still allow me to colour different countries - please let me know.
There's lots out there -- it would be even nicer when an OGC Registry
implentation makes it way out there, so we can all discover data (should
increase once the deegree WCAS gets out there later this summer).
Offhand, here are a few WMS instances with some global data:
CubeWerx DCW/VMAP:
http://demo.cubewerx.com/demo/cubeserv/cubeserv.cgi
Layer: lots -- you'll have to sift through
ENVISAT MERIS mosaic
Server: http://mapserv2.esrin.esa.it/ionicweb/map/GAEL_WORLD_MARCH
Layer name: GAEL_WORLD_MARCH
MODIS mosaic
Server: http://mapserv2.esrin.esa.it/cubestor/cubeserv/cubeserv.cgi
Layer name: WORLD_MODIS_1KM:MapAdmin
DEMIS World Map:
http://www2.Demis.nl/MapServer/Request.asp
Hope this helps.
..Tom
> Thanks again Tom!
> Kind Regards.
> William.
> >>From: mapserver-users-admin at lists.gis.umn.edu
> >>[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> >>William White
> >>Sent: Thursday, July 01, 2004 5:02 PM
> >>To: mapserver-users at lists.gis.umn.edu
> >>Subject: [Mapserver-users] SLD and mapserver...
> >>Hello mapserver enthusiasts,
> >>I am interested in displaying a very simple world political
> map on my
> >>global financial markets page
> >>(http://www.zenfinder.com/finance/globalMarkets.php).  I
> >>would like to
> >>fill specific countries with different colours based upon the
> >>percentage
> >>change of that country's major securities index.
> >> From what I can gather - I should be able to do this pretty easily
> >>using SLD, assuming I can find a server with a world politcal
> >>map which
> >>supports SLD for that particular layer.
> >>I found a world political map that appears to have SLD enabled:
> >>http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeR
> >>sIoN=1.1.1&Request=GetMap&LAYERS=WorldPolitical
> >>but when I pass in my XML doc (see below) it doesn't appear to be
> >>working.  My syntax may be incorrect or potentially this
> >>server does not
> >>accept this type of SLD?  I am assuming if I download the mapserver
> >>software, I should be able to render the desired map on my
> >>home computer
> >>but I would much prefer to be able to leverage an existing server.
> >Very good choice!
> >>Since my requirements are quite simple (I just need to be
> >>able to colour
> >>a world map) - I am hoping there is an existing server which I can
> >>reference and simply pass in the various style descriptors (of the
> >>countries that need to be filled in) via the querystring or
> >>an xml doc
> >>referenced in the querystring.
> >>Does anyone know of a server that would allow me to do this/what I'm
> >>doing wrong with this one?  Any guidance or advice
> regarding this or
> >>perhaps a simpler solution would be extremely appreciated!!!
> >A couple of issues:
> >- you don't need the 'sld:' prefix in your XML elements.
> The default
> >namespace of the SLD document should be the same as xmlns:sld
> >- you don't need to put quotes around the Literal values
> >I've attached a file which works with this WMS if you pass,
> along with
> >your GetMap request:
> >"SLD=<urlOfSldDocument>"
> >>Thanks in advance.
> >>William.
> >>This is the xml doc I'm currently passing in as an SLD.
> >><?xml version="1.0" encoding="UTF-8"?>
> >><sld:StyledLayerDescriptor version="1.0.0"
> >>xmlns:sld="http://www.opengis.net/sld"
> >>xmlns:ogc="http://www.opengis.net/ogc"
> >>xmlns:gml="http://www.opengis.net/gml"
> >>xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> >><sld:NamedLayer>
> >><sld:Name>WorldPolitical</sld:Name>
> >><sld:UserStyle>
> >><sld:Name>StyleName1</sld:Name>
> >><sld:FeatureTypeStyle>
> >><sld:Rule>
> >><ogc:Filter>
> >><ogc:Or>
> >><ogc:PropertyIsEqualTo> <ogc:PropertyName>NAME</ogc:PropertyName>
> >><ogc:Literal>'Brazil'</ogc:Literal>
> >></ogc:PropertyIsEqualTo>
> >><ogc:Literal>'Canada'</ogc:Literal>
> >></ogc:Or>
> >></ogc:Filter>
> >><sld:PolygonSymbolizer>
> >><sld:Fill>
> >><sld:CssParameter name="fill">#FF0000</sld:CssParameter>
> >><sld:CssParameter name="fill-opacity">1.0</sld:CssParameter>
> >></sld:Fill>
> >><sld:Stroke>
> >><sld:CssParameter name="stroke">#FF0000</sld:CssParameter>
> >><sld:CssParameter name="stroke-opacity">1.0</sld:CssParameter>
> >><sld:CssParameter name="stroke-width">1</sld:CssParameter>
> >><sld:CssParameter name="stroke-linecap">butt</sld:CssParameter>
> >></sld:Stroke>
> >></sld:PolygonSymbolizer>
> >></sld:Rule>
> >></sld:FeatureTypeStyle>
> >></sld:UserStyle>
> >></sld:NamedLayer>
> >></sld:StyledLayerDescriptor>
> >>_______________________________________________
> >>Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> >>http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
