[Mapserver-users] msDrawMap() error
Brent Fraser
bfraser at geoanalytic.com
Sun Jul 4 10:38:32 EDT 2004
Oliver,
Does the shapefile
"C:\library\sites\mapserver\projects\testing\mapserver\admin.shp" (and it's
.dbf and .shx) exist? Are the permissions on the file set so IIS can read
it?
I'm not sure why mapserver gave two messages (one for "testing\admin" and
one for "testing\mapserver\admin"). Try deleting the SHAPEPATH setting and
putting the full path to the shapefile in the DATA statement:
NAME luzon
DATA "C:\library\sites\mapserver\projects\testing\mapserver/admin"
STATUS DEFAULT
TYPE POLYGON
If it doesn't work then there is likely a problem with the file or the
security on the file/folders.
Brent Fraser
----- Original Message -----
From: "Oliver Ishmael" <oliver_ishmael at hotmail.com>
To: <mapserver-users at lists.gis.umn.edu>
Sent: Sunday, July 04, 2004 5:09 AM
Subject: [Mapserver-users] msDrawMap() error
> Hi all,
> i am still trying to write my first .map file but have run into the
> following errors:
> msDrawMap(): Image handling error. Failed to draw layer named 'luzon'.
> msSHPOpenFile(): Unable to access file.
> (C:\library\sites\mapserver\projects\testing\admin)
> (C:\library\sites\mapserver\projects\testing\mapserver/admin)
> I have attached a copy of my .map file and hope that someone can offer a
> little help. As always any help greatly appreciated.
> Cheers
> Oliver Ishmael
> _________________________________________________________________
> Stay in touch with absent friends - get MSN Messenger
> http://www.msn.co.uk/messenger
