DXF in mapserver (was Re: [Mapserver-users] (no subject) )
Daniele Margotti margottid at comune.lugo.ra.it
Tue Jul 6 03:32:57 EDT 2004
It doesn't work for me (although MapServer is correctly installed and
works very good).
My mapfile is:
MAP
  IMAGETYPE imagemap
  OUTPUTFORMAT
    NAME imagemap
    MIMETYPE "text/plain"
    DRIVER imagemap
    EXTENSION dxf
    FORMATOPTION DXF=ON
  END
END
I try to open this page:
http://localhost/cgi-bin/mapserv?mode=map&program=/cgi-bin/mapserv&map=/
data/DXF.map
And I get this error:
msDrawMap(): GD library error. Unable to initialize image.
What do I need?
What is "DRIVER imagemap"? A particular driver?
I found mapimagemap.c in MapServer installation directory, is it
related? And how can I use it?
Thank you in advance,
   Daniele
-----Messaggio originale-----
Da: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu] Per conto di Tyler
Mitchell
Inviato: lunedì 5 luglio 2004 17.35
A: bartvde at xs4all.nl
Cc: Irene Pérez; mapserver; mapserver-users-admin at lists.gis.umn.edu
Oggetto: DXF in mapserver (was Re: [Mapserver-users] (no subject) )
Semi-related:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0309/msg00030.h
tml
mapserver-users-admin at lists.gis.umn.edu wrote on 07/02/2004 03:34:27 AM:
> Hi,
> No it doesn't. But you could always convert it by using e.g. FME.
> BTW: try putting a more meaningful e-mail subject line next time.
> Best regards,
> Bart
> > Hi everyone,
> > Does anyone know if MapServer supports DXF format?
> > Thanks in advance.
> > Regards,
> > Irene
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
