[Mapserver-users] Re: Rosa applet and Virtual machines (Valerio Noti)
Lowell Filak
lfilak at medinaco.org
Fri Jul 9 13:02:36 EDT 2004
This may be of interest:
http://www.microsoft.com/mscorp/java/faq.asp
Lowell
The following message was sent by "Valerio Noti" <noti at ciaoweb.it> on
Fri, 9 Jul 2004 18:48:50 +0200.
> Thank you for your response Kristjan,
> since Microsoft cannot distribute his JVM for legal problems, I'm very
> confused about the use of Java.
> If Sun JVM is unstable and slow with map applets, do you think I have to
> abandon definitively Java or
> are there any solutions to this problem? is it possible (and legal) to
> install the old Microsoft JVM where it is not installed?
> Thanks again.
> Valerio
> ----- Original Message -----
> From: "Kristjan Annus" <kristjan at tarkvarastuudio.ee>
> To: <mapserver-users at lists.gis.umn.edu>
> Sent: Friday, July 09, 2004 9:17 AM
> Subject: [Mapserver-users] Re: Rosa applet and Virtual machines (Valerio
> Noti)
> > Hi Valerio
> > I have tested both VM-s and have made the same conclusions, that Sun VM
> > is slow and unstable
> > with Rosa applet. In fact in older versions on Sun VM the setimage
> > method of the applet does not
> > work at all. I have encountered the same problems with Mapplet and Jbox
> > applet's allso. So that
> > I think the problem is rather in Sun VM than in applet's itself.
> > Kristjan
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
