[Mapserver-users] php query
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Wed Jul 14 04:35:34 EDT 2004
Michael Smith schrieb:
> Hi,
> I am just starting to learn php. I have mapserver up and running on windows
> IIS. Does anyone have any php code to perform a search for a street and
> display it on a map in mapserver that they would be willing to share? I
> would like my users to be able to type in a street name and zoom to it, I am
> just not able to do this and would like to learn how. Any help will be
> useful for me. Thank you.
> Mike
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
I have not the whole code for you but I can give the direction to solve
this yourself. Also I'm sure this is not the best way.
Because you first started with PHP you should play around a bit before
going into the mapscript. After that the place to start is:
http://mapserver.gis.umn.edu/doc42/phpmapscript-class-guide.html
You should get familiar to this doc. There you find all the objects with
their functions and parameters. You also find predefined keywords like
"MS_SUCCESS". If you look through the doc you can often see at the
beginning of an object part how to create such an object. There is
always a set() function to change the parameters. Only for some
parameters you will find specific functions.
Depending on the object you have different other functions. In front of
the function you can see what type of object it returns. Then you see
the name of the function and the possible/necessary input parameters and
their types. For example:
int queryByAttributes(string qitem, string qstring, int mode)
which is the function to search a word in a field of the attribute table
of the layer-data. You can use this function for your problem:
$layer->queryByAttributes("the field with the names", "the name to
search", 0);
$layer is the object representing your street layer. The "->" is to
address the function. The qitem/qstring you have to change to your needs
but you have to put it in "" because these are strings. The 0 can also
be chnaged to 1. The 0 means that the query mode is MS_SINGLE so only
one result will be found. The 1 will find all features that have this
criterion if there are more then one.
I think the qstring must be exact the same (case sensitive) like in the
field of the attribute table. This could be a problem. If you want to
get around that you can use php's dbase modul or odbc modul. But for the
first application the mapscript should do it. Perhaps you should make a
dropdown list of the possible names instead of a textfield to avoid
problems.
To check if something is found you can use the function like the
following because the results get saved in the resultcache of the layer.
You can add the @ in front of $layer to disable the messages or you can
just leave it:
if (@$layer->querybyattributes($sq_attr_field, $sq_attr_string, $q_mode)
== MS_SUCCESS)
$res_count = $layer->getnumresults(); // get the number of results
for ($i = 0; $i < $res_count; $i++) // loop through the results ->
only if you expect more then one result (not necessary in single mode)
$result = $layer->getResult($i); // get the result which includes
the indexes of the found shape
$shp_index = $result->shapeindex;
$tile_index = $result->tileindex;
$layer->open(); // open the layer to get the shapeobject of the feature
$shp = $layer->getshape($tile_index, $shp_index);
// FYI: if you want to get the items and the values to the items you
ccan get that from that shapeobj --> so you can go through all the
features and get the street names for the dropdown list - this is surely
not the best method to do that but you can use it
$layer->close(); // close the layer
$shp_bound = $shp->bounds; // get the extent of the feature
if ($shp_bound->project($layer_prj, $map_prj) == MS_SUCCESS) //
change the projection of the layer to the one of the map
// next: calculate a buffer for the extent ($res_rect_buf can be between
1 and 100 -> %) --> I hope that there is nothing wrong so please check that
$res_buf_minx = $shp_bound->minx - ($shp_bound->maxx -
$shp_bound->minx) * $res_rect_buf/200;
$res_buf_miny = $shp_bound->miny - ($shp_bound->maxy -
$shp_bound->miny) * $res_rect_buf/200;
$res_buf_maxx = $shp_bound->maxx + ($shp_bound->maxx -
$res_buf_maxy = $shp_bound->maxy + ($shp_bound->maxy -
// next: add the buffer to the extent
$shp_bound->set(minx, $res_buf_minx);
$shp_bound->set(miny, $res_buf_miny);
$shp_bound->set(maxx, $res_buf_maxx);
$shp_bound->set(maxy, $res_buf_maxy);
// next: save the extent of the map to the bounds of the shape + buffer
$tmp_extent = $map->extent;
$map->setextent($shp_bound->minx, $shp_bound->miny,
$shp_bound->maxx, $shp_bound->maxy);
$sq_img = $map->drawquery(); // draw the image
$sq_path = $sq_img->savewebimage(); // get the path of the image
// next: set the extent of the map back --> only if you want that
$map->setextent($tmp_extent->minx, $tmp_extent->miny,
$tmp_extent->maxx, $tmp_extent->maxy);
else
echo "<br>Problem with the projection.";
Good luck,
Norbert
