[Mapserver-users] Access to "FEAUTRE" using MapScript
Lowell Filak lfilak at medinaco.org
Wed Jul 14 15:06:24 EDT 2004
Oops, thanks Sean - I forgot.
Lowell
The following message was sent by Sean Gillies <sgillies at frii.com> on
Wed, 14 Jul 2004 12:57:24 -0600.
> Manuel, Lowell:
> There's been a layerObj.addFeature() in the SWIG mapscript for some
> time, but is absent from PHP mapscript.
> Lowell, I'm with you on this ... I don't think that inserting feature
> data into the mapObj is a good practice.  But the capability is there.
> cheers,
> Sean
> On Jul 14, 2004, at 12:14 PM, Lowell Filak wrote:
> > I'm not a developer but... I'm not sure that the feature object should
> > be exposed to mapscript.
> > The idea is that "feature" allows the dynamic creation of entities via
> > the mapserv cgi whereas in MapScript you can already create a point
> > object dynamically.
> > Lowell
> > =?iso-8859-1?Q?Manuel_Marichal_P=E9rez?= > <mmarichal at buscamap.com> on
> > Wed, 14 Jul 2004 09:52:20 +0100.
> >> Hi all. I've got a layer like this in my map:
> >> LAYER
> >>  NAME "Logo"
> >>  TYPE POINT
> >>  STATUS ON
> >>  TRANSFORM FALSE
> >>  FEATURE POINTS 485 15 END END
> >>  CLASS
> >>   SYMBOL "LOGO"
> >>  END
> >> END
> >> I'd like to modify the x-coordinate of the logo from my php code. How
> >> can I access to "FEATURE" member with MapScript?. There is not a
> >> "getFeature" method in the Layer class, isn't?.
> >> Thanks in advance
> >> Manuel Marichal Pérez
