[Mapserver-users] null values in postgis
Vladimir Guzmán bigfoot at main-task.com
Fri Jul 16 15:38:59 EDT 2004
I've had a simmilar problem, but with oracle, and what I did was a
casting, for example:
data=the_geom FROM (SELECT CASE WHEN field IS NULL THEN ' ' ELSE
CAST(field AS VARCHAR) END AS field)
And the expression would be:
EXPRESSION ([field] = ' ')
I don't know if there is a better way to do that, but it worked.
Hope that helps,
Vladimir Ilich Guzmán R.
http://maintask.com
Kathi Koebke wrote:
> Hello,
> does anybody know about problems displaying null values in mapserver ?
> I 'm working with Postgresql/postgis and I have emtpty fields (missing
> values) in my tables.
> I want to classify the data and I have to display missing values in my
> map.  EXPRESSION ([ha_ges] is null) did not work .
> Any Ideas?!
> Thanks Kathi Köbke
