FW: [Mapserver-users] Mapserver Postgis connection issues
Swaminathan, Gayathri gayathri at ou.edu
Mon Jul 19 09:38:01 EDT 2004
-----Original Message-----
Sent: Sunday, July 18, 2004 11:57 AM
To: 'Tyler Mitchell'
Subject: RE: [Mapserver-users] Mapserver Postgis connection issues
So I finally had the issue solved...
I had registered the libpq.dll that came in Mark Ayland's snapshot for use with mapserver v.4.2.1
This dint work well...It had the mapserver cgi--hung up
So I took Tyler's suggestion and tried from shp2img...and checked my postgresql log and saw that there was no postgresql connection requests being made!!!
Then... I took  Juan's suggestion and replaced my libpq.dll with the one that came with mapserver 42 bundle (http://hypnos.cbs.umn.edu/projects/downloads/ms42pg.zip) and it works!!!!!!!!
So this was another mismatched dll-o-rama!
Thanks for all your help...and time
Gayathri
>Finally I ran a test with the SQL on windows and unfortunatelly the
>solution
>I gave was uncorrect, the php crashed because of a problem with the
>libpq.dll. So what I did this time was to copy again the mapserver binaries
>dll file on the system32 dir.
> What I find curious is that the posgres server seems to run ok even.
>Well, at least, it seems to work for me.
> I Hope you solve your problems. Juan.
> From: Swaminathan, Gayathri
> Sent: Friday, July 16, 2004 3:45 PM
> Cc: Vladimir Guzmán; Kathi Koebke;
> mapserver-users at lists.gis.umn.edu;
> mapserver-users-admin at lists.gis.umn.edu
> Ok I tried shp2img... As follows:
> C:\Inetpub\cgi-bin>shp2img -m
> c:\Inetpub\wwwroot\athena\mapODOC.map -o c:\out.png -l sqlSewerline
> and it returns a blank image with my IMAGEBACKGROUND set in
> the mapfile.
> sqlSewerline is my postgis layer.
> The above command works fine for shape files though and
> renders out.png with parcels...
> > From: Tyler Mitchell [mailto:tjmitchell at riverside.bc.ca]
> > Sent: Friday, July 16, 2004 3:29 PM
> > To: Swaminathan, Gayathri
> > Subject: Re: [Mapserver-users] Mapserver Postgis connection issues
> > > If I added a Postgis layer however..I am having the mapserver cgi
> > > run indefinetely and locking up.
> > Are you using any sort of java interface in your web page? I would
> > try to debug by using the command line shp2img command instead.
> > See if it throws any errors.
