[Mapserver-users] null values in postgis
Vladimir Guzmán bigfoot at main-task.com
Wed Jul 21 07:48:08 EDT 2004
Hello, Kathi.
Could you post the data statement you're trying to use?
Tschuess,
Vladimir Ilich Guzmán R.
http://maintask.com
Kathi Koebke wrote:
> Hey Vladimir,
> Thank your for help. I was testing to work with the cast statement but
> it dosen't work . I think there is something work in my cast
> statement  for postgresql and i have to check it out or to find
> another way, because I don't want to take hand on the original data.
> Could it be a bug in mapserver?
> Hasta luego
> Kathi
> Vladimir Guzmán schrieb:
>> I've had a simmilar problem, but with oracle, and what I did was a
>> casting, for example:
>> data=the_geom FROM (SELECT CASE WHEN field IS NULL THEN ' ' ELSE
>> CAST(field AS VARCHAR) END AS field)
>> And the expression would be:
>> EXPRESSION ([field] = ' ')
>> I don't know if there is a better way to do that, but it worked.
>> Hope that helps,
