[Mapserver-users] OGR Layer with SQL
Blaine Hackett
blaine_hack1 at yahoo.com
Wed Jul 28 13:08:17 EDT 2004
All
I am having a problem using SQL with OGR. The
following SQL statement works:
<SrcSQL>SELECT * FROM subset (time > '6:00:00 AM'
</SrcSQL>
but if I make it complex like this:
<SrcSQL>SELECT * FROM subset (time > '6:00:00 AM') AND
(time < '7:30:00 AM') </SrcSQL>
It throws this error:
msOGRFileOpen(): OGR error. Open failed for OGR
connection ` ODBC:ODBC:user/pass at minnesotadata SELECT
* FROM subset (time > '6:00:00 AM') AND (time <
'7:30:00 AM') wkbPoint WGS84 '. File not found or
unsupported format.
The SQL syntax I am using is exactly like the syntax
shown on
http://www.remotesensing.org/gdal/ogr/ogr_sql.html.
I have tried every combination of quotes and
parenthesis and uppercase and lowercase without
success. I have also tried copying and pasting from
the Access SQL window since that is the database I am
linking to but that does not work at all.
Anyone have any ideas what I am doing wrong?
Blaine
__________________________________
Do you Yahoo!?
Y! Messenger - Communicate in real time. Download now.
http://messenger.yahoo.com
