[Mapserver-users] Shared library error with PHP MapScript
Doug
ummmmm at myrealbox.com
Wed Jul 28 15:24:58 EDT 2004
Daryl Herzmann wrote:
> Howdy,
> I will take a stab...
> On Wed, 28 Jul 2004, Doug wrote:
>> Fedora Core 2, Apache 2, PHP 4.3.8, PHP-MapScript 4.2.1.
>> When we dl("php_mapscript.so") in a test php file, we get:
>> PHP Warning: dl(): Unable to load dynamic library
>> '/usr/lib/php4/php_mapscript.so' - libpq.so.3: cannot open shared
>> object file: No such file or directory in /var/www/html/test.php on
>> line 2
>> in Apache's error log. But when we run the same file from the
>> command-line (php test.php), there is no error and the MapScript
>> section of phpinfo() is displayed fine.
>> Also, ldd/usr/lib/php4/php_ mapscript.so seems to show no problems
>> with any of its .so files, including libpq.so.3.
> Where is libpq.so.3 located on the system? Is it /usr/local/pgsql/lib/ ?
Yes.
> Can the user that apache is running as have permissions to see this file?
Aargh! Now that's stupid. I had already looked at the specific file's
permissions, and they were fine, as they were for /usr/local/pgsql/lib.
But they weren't for /usr/local/pgsql. Fixed that, and my test page
worked. Thanks for getting me to look again. <Kick, kick>
> Just for kicks, run the locate command see if there are any other libs
> hanging out on the system
> locate libpq.so.3
> locate php_mapscript.so
> HTH,
> daryl
