[Mapserver-users] bug postgis query alias
strk
strk at keybit.net
Tue Jun 1 06:12:20 EDT 2004
On Mon, May 31, 2004 at 03:29:45PM -0500, Vladimir Guzmán wrote:
> Hello.
> I'm implementing a gps tracking system.
> I want to show the car's orientation like this:
> http://maintask.com/test.png
> The layer's data is something like this:
> gps_geom from (select gid,sentido,tiempo,360-rumbo+90 as
> rumbo,velocidad,gps_geom,oid from gps_vehi where tiempo>='2004-05-29
> 05:00:00' and tiempo<='2004-05-30 04:59:59') as foo using unique gid
> using srid=1
> The field 'sentido' contains '>'.
> The problem is that if I use something like this:
> gps_geom from (select gid,'>' as sentido,tiempo,360-rumbo+90 as
> using srid=1
> The query doesn't work.
> So I had to create a column in potgres called 'sentido' and all the rows
> containing '>'.
> Is this a bug?
What's the error message ?
Can you run the query from the pgsql monitor ?
--strk;
> The rest of the layer:
> LAYER
> NAME "puntosgps"
> CONNECTIONTYPE postgis
> CONNECTION "user=gps password=gps dbname=gps host=localhost"
> DATA "gps_geom from (select gid,sentido,tiempo,360-rumbo+90 as
> using srid=1"
> TYPE POINT
> PROJECTION
> "proj=latlong"
> "datum=WGS84"
> END
> LABELANGLEITEM 'rumbo'
> LABELITEM 'sentido'
> CLASS
> NAME 'Parado'
> EXPRESSION ([velocidad] = 0)
> SIZE 14
> SYMBOL 'circle'
> COLOR 0 0 215
> OUTLINECOLOR 204 204 204
> END
> CLASS
> NAME '0-10'
> EXPRESSION ([velocidad] > 0 AND[velocidad] <= 10)
> SIZE 14
> SYMBOL 'circle'
> COLOR 255 255 204
> LABEL
> TYPE TRUETYPE
> FORCE TRUE
> FONT arial
> ANTIALIAS TRUE
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> SIZE 8
> END
> END
> Thanks a lot.
> Vladimir Ilich Guzmán R.
> http://maintask.com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
