[Mapserver-users] bug postgis query alias
Vladimir Guzmán
bigfoot at main-task.com
Tue Jun 1 08:04:23 EDT 2004
Yes, the query runs fine in the pgsql monitor:
gps=> select gid,'>' as sentido,tiempo,360-rumbo+90 as
rumbo,velocidad,gps_geom,oid from gps_vehi where tiempo>='2004-05-31
05:00:00' and tiempo<='2004-06-02 04:59:59';
gid | sentido | tiempo | rumbo | velocidad |
gps_geom | oid
46275 | > | 2004-05-31 15:16:09 | 450 | 0 |
SRID=1;POINT(-74.06318 4.67302) | 7731018
46276 | > | 2004-05-31 15:16:15 | 450 | 0 |
SRID=1;POINT(-74.06318 4.67302) | 7731019
46277 | > | 2004-05-31 15:16:21 | 450 | 0 |
SRID=1;POINT(-74.06319 4.67301) | 7731020
The error is just:
*Warning*: MapServer Error in msDrawMap(): Failed to draw layer named
'puntosgps'.
in */usr/local/apache/htdocs/gps/index.phtml* on line *33*
Vladimir Ilich Guzmán R.
http://maintask.com
strk wrote:
>On Mon, May 31, 2004 at 03:29:45PM -0500, Vladimir Guzmán wrote:
>>Hello.
>>I'm implementing a gps tracking system.
>>I want to show the car's orientation like this:
>>http://maintask.com/test.png
>>The layer's data is something like this:
>>gps_geom from (select gid,sentido,tiempo,360-rumbo+90 as
>>rumbo,velocidad,gps_geom,oid from gps_vehi where tiempo>='2004-05-29
>>05:00:00' and tiempo<='2004-05-30 04:59:59') as foo using unique gid
>>using srid=1
>>The field 'sentido' contains '>'.
>>The problem is that if I use something like this:
>>gps_geom from (select gid,'>' as sentido,tiempo,360-rumbo+90 as
>>using srid=1
>>The query doesn't work.
>>So I had to create a column in potgres called 'sentido' and all the rows
>>containing '>'.
>>Is this a bug?
>What's the error message ?
>Can you run the query from the pgsql monitor ?
>--strk;
>>The rest of the layer:
>>LAYER
>> NAME "puntosgps"
>> CONNECTIONTYPE postgis
>> CONNECTION "user=gps password=gps dbname=gps host=localhost"
>> DATA "gps_geom from (select gid,sentido,tiempo,360-rumbo+90 as
>>using srid=1"
>> TYPE POINT
>>PROJECTION
>> "proj=latlong"
>> "datum=WGS84"
>>END
>> LABELANGLEITEM 'rumbo'
>> LABELITEM 'sentido'
>> CLASS
>> NAME 'Parado'
>> EXPRESSION ([velocidad] = 0)
>> SIZE 14
>> SYMBOL 'circle'
>> COLOR 0 0 215
>> OUTLINECOLOR 204 204 204
>> END
>> CLASS
>> NAME '0-10'
>> EXPRESSION ([velocidad] > 0 AND[velocidad] <= 10)
>> SIZE 14
>> SYMBOL 'circle'
>> COLOR 255 255 204
>> LABEL
>> TYPE TRUETYPE
>> FORCE TRUE
>> FONT arial
>> ANTIALIAS TRUE
>> COLOR 0 0 0
>> OUTLINECOLOR 255 255 255
>> SIZE 8
>> END
>> END
>>Thanks a lot.
>>http://maintask.com
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
