[Mapserver-users] Symbol - GIF pixmap - parsing problem
Jenu Abraham
jenu_ab at hotmail.com
Tue Jun 1 14:52:51 EDT 2004
thanks
Got this problem fixed..
I am using windows 2003 server..
i had checked all the permissions and it did have full control ..
but stilll it was showing that error...
The problem was..the image should have the allow inheritable permission
checked...I dont know why this is necessary.
cheers
jenu
>From: Siki Zoltan <siki at agt.bme.hu>
>To: Jenu Abraham <jenu_ab at hotmail.com>
>CC: mapserver-users at lists.gis.umn.edu, <flavio at tydac.ch>
>Subject: Re: [Mapserver-users] Symbol - GIF pixmap - parsing problem
>{Scanned}
>Date: Tue, 1 Jun 2004 20:33:35 -0100 (GMT+1)
>Hi,
>Have you checked the access rights to that file?
>The web server must have read access to that file.
>Do you use unix or windows?
>on unix use the "ls -l file-name" command to check access right,
>you should see -rw-r--r-- or -rw-rw-r-- at the beginning of the line
>there should be three "r"
>on windows right click on the file in windows explorer and select
>properties ...
>Bye
>Zoltan
>On Tue, 1 Jun 2004, Jenu Abraham wrote:
> > i'm facing a very peculiar problem
> > when i was testing Symbol Pixmap ...everything worked fine with a gif
>file
> > "north.gif" which i had downloaded from an example for mapserver...
> > now i tried to develop my own image of a comapss . I converted it to
> > "north.gif".
> > When i tried to run this.....it gave a
> > "loadsymbol().Unable to access file. Parsing error near(my image path)"
> > when i again used my old image it worked
> > can somebody tell me why.?
> > I haVE CHECKED the image does exist at the path....
> > jenu
> > _________________________________________________________________
> > Is your PC infected? Get a FREE online computer virus scan from McAfee®
> > Security. http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Learn to simplify your finances and your life in Streamline Your Life from
MSN Money. http://special.msn.com/money/0405streamline.armx
