[Mapserver-users] EPSG codes
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Wed Jun 2 08:41:19 EDT 2004
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> Delfos, Jacob
> Sent: Wednesday, June 02, 2004 12:28 AM
> To: mapserver-users
> Subject: RE: [Mapserver-users] EPSG codes
> Daniel,
> What would be the correct way of requesting an entry to be
> added to the official EPSG? I tried to find out, but I
> haven't been able to find a person in charge of that.
You may want to check with http://www.epsg.org/. Having said this, I
believe CubeWerx has reserved the 42xxx block of EPSG codes, of which
42304 is one of them.
..Tom
> Jacob
> From: Daniel Morissette [mailto:dmorissette at dmsolutions.ca]
> Sent: Wednesday, 2 June 2004 12:12 PM
> To: Zamil Murji
> Cc: mapserver-users
> Subject: Re: [Mapserver-users] EPSG codes
> Zamil Murji wrote:
> > Hello list,
> > I am very new to epsg codes and I'm having some difficulty
> finding the
> > correct code to use. Currently I am using a 4269 to show all of
> > canada, however, this makes everything look so
> disproportionate. I am
> > looking to use the lambert conical or lambert cylindrical
> codes, but I
> > can't find them anywhere. Ideally I would like to use the same
> > projection as the gmap application on the dmsolutions website.
> There is no LCC for Canada as part of the official EPSG list, but
> several sites recognize the unofficial code "EPSG:42304":
> ## NAD83 LCC for Canada
> <42304> +proj=lcc +ellps=GRS80 +lat_0=49 +lon_0=-95 +lat_1=49
> +lat_2=77
> +datum=NAD83 +units=m no_defs <>
> If you want to use this code with MapServer then you'll have
> to add the
> line above to your PROJ4 "epsg" file, or download the
> following patched
> version:
http://maptools.org/dl/proj4-epsg-with-42xxx.zip
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
