[Mapserver-users] Virtual Spatial Data - projection
Jenu Abraham jenu_ab at hotmail.com
Wed Jun 2 11:48:49 EDT 2004
still no points showing up on the map....
this is how my table looks now
table: latlong
x             |        y
41.5         |     -87.5
35.5         |     -97.4
>From: "Pagurek, Debbie" <PAGUREKD at AGR.GC.CA>
>To: "Jenu Abraham" <jenu_ab at hotmail.com>,
><mapserver-users at lists.gis.umn.edu>
>Subject: RE: [Mapserver-users] Virtual Spatial Data - projection
>Date: Wed, 2 Jun 2004 10:06:54 -0400
>You have the negative in the wrong place.
>e.g. Chicago should be 41.5  -87.2
>Debbie
>-----Original Message-----
>From: mapserver-users-admin at lists.gis.umn.edu
>[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Jenu
>Abraham
>Sent: Tuesday, June 01, 2004 4:12 PM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] Virtual Spatial Data - projection
>guys...
>i have been trying to plot points on a US map using latlong cordinates
>from
>my SQL table using virtual spatial data
>ogrinfo gave the correct output..with testing2.ovf
>eg:  -35.5 97.4 oklahomaq city
>       -41.5 87.2 chicago
>i can see the states layer but
>i dont see any points on my map..from the truck layer
>why? is something wrong in the projection
>MAP
>   NAME           e-test-rd-jbox-vsd_
>   IMAGETYPE      GIF
>   EXTENT          -2236857.50 -1744057.00  2786329.50 29069.36
>   SIZE           800 600
>   SHAPEPATH      "C:\cgi-bin\data\"
>   FONTSET        "C:\cgi-bin\fonts\fonts.list"
>   WEB
>     TEMPLATE 'e-test-rd-jbox.html'
>     IMAGEPATH 'C:\cgi-bin\tmp\'
>     IMAGEURL  '/tmp/'
>   END
>   PROJECTION
>     "init=epsg:2163"
>    END
>   LAYER # States polygon layer begins here
>     NAME         states
>     DATA         statesp020
>     STATUS       DEFAULT
>     TYPE         POLYGON
>     PROJECTION
>       "init=epsg:4326"
>     END
>     CLASS
>         COLOR      240 240 100
>     END
>   END # States polygon layer ends here
>LAYER # start of truck position from database
>	NAME trucks
>	TYPE POINT
>	CONNECTIONTYPE OGR
>	CONNECTION "testing2.ovf"
>	DATA "mylayer"
>	STATUS DEFAULT
>	PROJECTION
>       	  "proj=latlong"
>	END
>	CLASS
>		SYMBOL 1
>		SIZE 6
>      		COLOR      255 0 0
>	END
>END # end of connection layer
># End of LAYER DEFINITIONS
>END # end of map file
_________________________________________________________________
FREE pop-up blocking with the new MSN Toolbar – get it now!
http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
