[Mapserver-users] Virtual Spatial Data - projection
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Jun 2 12:01:30 EDT 2004
lat = Y
lon = X
you might want to swap you data columns.
-Steve W.
Jenu Abraham wrote:
> still no points showing up on the map....
> this is how my table looks now
> table: latlong
> x | y
> 41.5 | -87.5
> 35.5 | -97.4
>> From: "Pagurek, Debbie" <PAGUREKD at AGR.GC.CA>
>> To: "Jenu Abraham" <jenu_ab at hotmail.com>,
>> <mapserver-users at lists.gis.umn.edu>
>> Subject: RE: [Mapserver-users] Virtual Spatial Data - projection
>> Date: Wed, 2 Jun 2004 10:06:54 -0400
>> You have the negative in the wrong place.
>> e.g. Chicago should be 41.5 -87.2
>> Debbie
>> -----Original Message-----
>> From: mapserver-users-admin at lists.gis.umn.edu
>> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Jenu
>> Abraham
>> Sent: Tuesday, June 01, 2004 4:12 PM
>> To: mapserver-users at lists.gis.umn.edu
>> Subject: [Mapserver-users] Virtual Spatial Data - projection
>> guys...
>> i have been trying to plot points on a US map using latlong cordinates
>> from
>> my SQL table using virtual spatial data
>> ogrinfo gave the correct output..with testing2.ovf
>> eg: -35.5 97.4 oklahomaq city
>> -41.5 87.2 chicago
>> i can see the states layer but
>> i dont see any points on my map..from the truck layer
>> why? is something wrong in the projection
>> MAP
>> NAME e-test-rd-jbox-vsd_
>> IMAGETYPE GIF
>> EXTENT -2236857.50 -1744057.00 2786329.50 29069.36
>> SIZE 800 600
>> SHAPEPATH "C:\cgi-bin\data\"
>> FONTSET "C:\cgi-bin\fonts\fonts.list"
>> WEB
>> TEMPLATE 'e-test-rd-jbox.html'
>> IMAGEPATH 'C:\cgi-bin\tmp\'
>> IMAGEURL '/tmp/'
>> END
>> PROJECTION
>> "init=epsg:2163"
>> END
>> LAYER # States polygon layer begins here
>> NAME states
>> DATA statesp020
>> STATUS DEFAULT
>> TYPE POLYGON
>> PROJECTION
>> "init=epsg:4326"
>> END
>> CLASS
>> COLOR 240 240 100
>> END
>> END # States polygon layer ends here
>> LAYER # start of truck position from database
>> NAME trucks
>> TYPE POINT
>> CONNECTIONTYPE OGR
>> CONNECTION "testing2.ovf"
>> DATA "mylayer"
>> STATUS DEFAULT
>> PROJECTION
>> "proj=latlong"
>> END
>> CLASS
>> SYMBOL 1
>> SIZE 6
>> COLOR 255 0 0
>> END
>> END # end of connection layer
>> # End of LAYER DEFINITIONS
>> END # end of map file
> _________________________________________________________________
> FREE pop-up blocking with the new MSN Toolbar get it now!
> http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
