[Mapserver-users] store and draw route
Alexandros Chimarios alhim at intracom.gr
Thu Jun 3 02:35:50 EDT 2004
Storing the workers track in a Postgis enabled Postgres database and defining
a leayer in your map file of  data type LINE may solve your problem.
On Thursday 03 June 2004 04:44, Fu Chen wrote:
> Hi!
> I try to use mapserver and postgis to record and render the some mobile
> worker's route. Those routes are record by a data table like (workorID,
> time, position). In the webgis interface, we try to draw a route map by
> mapserver.
> Queried by the workor's ID, the position is sort by the time. then these
> points is linked with a line. We would like to draw a circle(or other
> symbol) on the key point if it is possible. I don't know how to write map
> file or mapscript to get the feature. Anybody can give me some suggestion?
> Thank you!
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
